Go to Post FIRST is a learning, growing and inspiring organization. We can never dictate pretty. We can however encourage and teach quality. - Steve W [more]
Unread 13-02-2004, 20:42
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
problem with navigate.c
Is their problem with code name navigate.c because i went on Mr Kevin's site and I downloaded tracker.c and i put that code in our robot and the sensors work but when i finally put navigate.c the code doesn't work. Anyone knows why? .
Unread 13-02-2004, 21:58
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: problem with navigate.c
From the FAQ:
Q: The servos don't rotate and the robot just spins in circles. What are we doing wrong?
A: It sounds like you're using the code in
navigate.zip. The code in navigate.c centers the servos, blindly drives the 'bot away from the diamond plate several inches, and then starts a counter-clockwise turn-in-place until the beacon comes into view of one of the sensors. Only then do the servos start tracking and the 'bot drives toward the beacon. The turn-in-place is done to ensure that the beacon would be well within the servos range of travel before they were allowed to track. This sounds like the behavior you're seeing. If all you want to do is try the trackers, upload tracker.hex (found in tracker.zip) instead of navigate.hex.
-Kevin
Kevin Watson
http://kevin.org
Unread 13-02-2004, 22:54
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Sir, actually the robot does even spin when we press the button it says drive to center and then does nothing, the tracker works almsot fine, with some problems at time becuase we havent made tubing on the servos yet.so sometimes i guess it picks up reflections.
Back to the point, but i read in another thread that we have to move the navigate() to autonomous and change a status of a variable somewhere so i will try tht. Please tell me if there is anything else to be done.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
joystick problem archiver 2000 12 23-06-2002 23:08
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
