Go to Post So once and a while no matter how addicted you may be, try to think outside the 48'x24' box of FIRST. - Tytus Gerrish [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 13-02-2004, 21:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Field Tolerances
Forgive me if this has been discussed elsewhere (I searched "tolerance" and did not find this topic) but I just read in the manual (I believe it is section 3.1.1) that field dimensions are + or - 1 inch!
Does this mean that the step has the possiblity of being 7 inches high? They say they will try to get it as close as reasonably possible but a 1 inch difference over 6 inches is a lot. What is the maximum amount higher it is likely to be?
Thanks.
Unread 13-02-2004, 22:14
Re: Field Tolerances
The things that vary by up to an inch will be things that very between regionals. For example, the positioning of the middle platform in relation to the rest of the field, and the height of the bar. The height of the steps is fixed once they cut the material, and will be much closer then 1 inch.
See the playing field in 3D Glasses General Forum 2 20-06-2005 20:57
Mobile/immobile objects on field Steve782 Rumor Mill 12 08-01-2004 04:15
Could the field be ice? dez250 Rumor Mill 15 03-01-2004 18:54
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Lego field wanted--URGENT!!! David Kelly General Forum 0 19-11-2001 12:17
