Go to Post Rules from prior years DO NOT APPLY to this year! - dlavery [more]
  #61   Spotlight this post!
Unread 30-01-2004, 16:39
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Mulit-postioning with pnuematics this year?
"White paper" posted in the technical section.
It is two pages - one text and one picture.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
  #62   Spotlight this post!
Unread 13-02-2004, 23:01
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
which page is it on
our web site
  #63   Spotlight this post!
Unread 13-02-2004, 23:07
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Originally Posted by sirbleedsalot
which page is it on
http://www.chiefdelphi.com/forums/pa...le&paperid=261
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
  #64   Spotlight this post!
Unread 14-02-2004, 00:30
FRC #0939
Team Role: Student
Thanks
our web site
  #65   Spotlight this post!
Unread 17-02-2004, 20:24
edflyerssn007's Avatar
edflyerssn007 edflyerssn007 is offline
AKA: Voice of God
#0329 (The P-Town Pirates)
edflyerssn007 is an unknown quantity at this point
Send a message via AIM to edflyerssn007
here's a corrected version of the schematic. Our skilled engineers (students) actually got working on our pnuematics board. includes relief valves to prevent overpressures on the exhaust side.
http://ndofwrldaswenoit.tripod.com/robotics/index.html
Team 329: The Raid. If there's an attic, we'll be there.
Where's IQ 92? Doutney
from MIT's Cogshop FAQ: "Robotics requires a very robust background (or, alternatively, a person with just about any background can work in robotics). There are elements of computer science, mechanical engineering, cognitive science, and lots of mathematics in the work that we do. There's also a great deal of "hacking" involved. "Hacking" is the art of taking something apart, breaking it, putting it back together with improvements, and then acting like you knew what you were doing all along."
  #66   Spotlight this post!
Unread 22-02-2004, 20:45
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
wow that is genus. i am amazed. speechless. perfect thread.
"You're not a real programmer until all your sentences end with semicolons;"
  #67   Spotlight this post!
Unread 02-03-2004, 13:53
Leo M Leo M is offline
#0384 (Tucker Tigers)
Leo M is just really niceLeo M is just really niceLeo M is just really niceLeo M is just really niceLeo M is just really nice
Against my better judgment, I am going to try to ride this horse one more time.
I have been thinking about this problem, and in experiments with the solenoids and trying out the ideas in this thread we have determined that – exactly as the manufacturer states – the valves will not change state reliably unless there is 30 psig at the ‘P’ port on the valve. In trying to make this happen with the ‘P’ port connected to the exhausting side of the cylinder, the 30 psig is not always there, and the valve will not shift reliably.
In addition, we want to avoid any rule-breaking involving going over the 60 psig limit for working air pressure, and not have to use a cumbersome solution involving regulators or relief valves in several different parts of the pneumatic circuit.
It is possible to purchase three –position solenoid valves with the center position having all ports blocked, or having the outlet ports pressurized. However, there is some question in my mind about the legality of these valves – it appears to me, at least, that the pneumatics rules and the flow chart are not in precise agreement. We would prefer to avoid the discussion with the judges if at all possible.
I have come up with a compromise solution shown in the accompanying file. Using two double solenoids, it is possible to supply air to the ‘P’ port of each valve, plug the ‘B’ outlets, direct the ‘A’ outlet of one valve to the ‘extend’ port, and the ‘A’ outlet of the other valve to the ‘retract’ port on the cylinder. To extend the piston, shift the valve on the extend port to supply air to the cylinder, and the valve on the retract port to exhaust. The 60 psig supply air at the ‘P’ ports will ensure that the valves shift when commanded. To retract, reverse the positions of both valves. And, to stop in mid-position, shift the valves so that air is supplied to both ports on the cylinder.
In the event that a force is applied to the device moved by the piston, any increase in air pressure above 60 psig will be relieved by the main regulator. Otherwise, the cylinder will be more-or-less locked in place by the 60 psig on both sides of the piston. Push hard enough and it will move, of course, but it will be possible to stop in mid-position as desired, using unquestionably legal components. The 60 psig working air pressure limit will not be exceeded, and the use of extra regulators or relief valves is avoided.
Leo M.
  #68   Spotlight this post!
Unread 02-03-2004, 14:15
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Leo,
If you applied the 60 psig to each side through both the solenoids wouldn't the cyclinder just continue to slowly extend since the forces won't equalize out?
Also if you shorten the tubing from the double exhaust to the single you should not have trouble getting 30 psig for port "P".
I believe reducing the regulator to ~55 psi will take care of the 60+ psi problem. You have to give up a little strength for control.
These are just my thoughts. Have you tested that circuit yet? Just curious to how well it worked.
  #69   Spotlight this post!
Unread 02-03-2004, 14:47
Unfortunately, I haven't been able to experiment as much as I would like to. This is just a concept. I thought I'd throw it out to the forum and see if anyone else could make something of it. There are a lot of other considerations in designing a system like this - what exactly is attached to the piston; how do static forces such as weight, or dynamic forces of parts in motion, affect the relative motion of the mechanism; how much time and money do you have to complete the system? The complicated nature is illustrated by the length of this thread. It holds some kind of fascination for us - I just know there is a way to solve this elegantly without violating rules, spending too much money, or needlessly complicating the circuit.
Maybe if we put check valves in the air supply lines to the solenoids???
Naaah - cuts off the regulator from the cylinder.
A good, hard problem - really fights back!
Leo M.
  #70   Spotlight this post!
Unread 02-03-2004, 15:40
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
I have actually worked with Leo on this one. It was going to be part of our bot this year, but the original use of the piston changed, so that now the idea of multi-positioning the piston is no longer needed. But back to the point, Leo and I have spent a good amount of time working on the concept. We have also found a way to make a piston stop in mid position where you want to just about every time you want it to, and it is pretty quickly at that. I'll give you guys a picture of it full out, full in and paused in mid throw. If there are any questions, PM me. I will say first off that you are best tho have the third solenoid to back pressure the system so that you get an quick responce from the solenoid that controls exaust from the main solenoid.
ivey
Name:	all the way in.jpg
ID:	1933  Click image for larger version
Name:	all the way out.jpg
ID:	1934  Click image for larger version
Name:	paused throw.jpg
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
  #71   Spotlight this post!
Unread 02-03-2004, 19:37
AKA: Voice of God
We built and tested our pnumatics circuit and its reliable. It performs the same way every time, we used the circuit in my last post. It is one of the cooler functions of our robot. Also the 60+psi overpressure issue never arose for us, so we didn't even need to include the second regulator.
  #72   Spotlight this post!
Unread 02-03-2004, 19:50
AKA: Nelson Green
This way works pretty reliable but I think the members of 384 are looking for a better solution for multipositioning since the rules allow more solenoids this year. Last year when we could only use a certain number of solenoids this was one of the few and definitely the easiest way to do this. It proved to be reliable for us. We never had any troubles with it other than general lack of use. Stacking wasn't a good strategy. If they have found a better solution to multiposition it would be good. I still stick with the way I posted is reliable, easy and generally legal. But the rule change has made things different so we'll see how else you can do things. I wish I had more involvemnet with my team this year so I could have tinkered with different pneumatic ideas I had. I'd like to try out there idea. Tinker with it a little. See if you can replace double solenoids with singles and how well it works compared to how well ours works. I like to see innovation but sometimes I like something reliable and easy.
  #73   Spotlight this post!
Unread 02-03-2004, 20:05
Jonathanb's Avatar
Jonathanb Jonathanb is offline
1037 S.C.R.E.A.M-a-holic
#1037 (S.C.R.E.A.M Team)
Team Role: Driver
Jonathanb is on a distinguished road
Send a message via AIM to Jonathanb
What we used this year were off the shelf items called pilot operated check valves. You attach two single solenoids to the check valves and the cylinder will hold any position you'd like it to
Jonathan
S.C.R.E.A.M 1037
www.teamfordfirst.org/team1037
2004 Detroit Website Design Award Winner
  #74   Spotlight this post!
Unread 02-03-2004, 21:35
AKA: theshadow
FRC #0620 (WarBots)
what i am playing with now with spare parts (we were going to do multi postition and then they bailed out on me because it looked to "complacated") is multi postition using the 3 valve system, with limit switches and the edu-controler. so far it works with 3 (all open and all closed not included) and its pretty good. there is a needle valve on the exaust valve, and i realy have to fine tune it because if its too far in it SLOW and if its too far out it overshoots by a lot (bad edu code i guess, im not using intruputs).
by next season im gonna have a nice display board and a white paper (WITH CODE). or so i plan...
  #75   Spotlight this post!
Unread 03-03-2004, 08:44
OK, I took another shot at it. I may well be working under restrictions that are excessive or unnecessary, but Hey - that's part of the fun. My last sketch would not work for the reasons pointed out by Mr. Green, and also because my line-up had a shunt between the two ports on the cylinder, so it wouldn't be locked in place. Here's another attempt - it adds a 60 psig regulator ahead of each solenoid valve. Now, the shunt line is eliminated, but the system is still protected from overpressure. This design does add a component, but regulators are reliable and (usually) trouble-free. It does give you the option of setting the pressure to the extend and retract ports separately, so any force imbalance due to area can be corrected by changing the pressure. At this point in the build, it is academic, but brains need exercise as much as muscles, especially as we get older (you'll find out). Besides, this is a good thread, and I hate to see it end.....
Leo M.
Championship Qualification - How you would've done it Ken Leung Championship Event 6 26-10-2003 14:00
Problems with this year... and a solution? archiver 2001 2 24-06-2002 03:23
Wow! what a year archiver 2000 8 23-06-2002 22:43
why why why...? archiver 2001 34 23-06-2002 22:13
Making heads or tails of the new announcement... Jessica Boucher General Forum 66 26-09-2001 11:13
