Go to Post It is one thing to be a great designer, it is another thing to be able to explain what you did, how things work, and why things happen. - Andy Baker [more]
Unread 14-02-2004, 00:27
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: Radio Cable Burning!!!
make sure u are following the power ditribution diagram for wiring your robot. And that you are using the right gauge wires. But if the insulation is also melting, there might be something wrong with your controller, you better check into this fast.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 14-02-2004, 07:35
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
I would double check the wiring and call innovation FIRST
Sounds like you have a MAJOR Problem and Innovation FIRST will probably send you a new RC
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 14-02-2004, 07:49
It sounds like your modem is working if you are running for a few minutes before the wires start to burn. If this is the case, it sounds like the power supply in the RC has gone bad. It is likely feeding raw 12 volts to the modem. This requires a call to Innovation FIRST. You likely have to return both the RC and the modem. This is the first time I have heard of this condition.
Unread 14-02-2004, 10:25
Cadetdan's Avatar
Cadetdan Cadetdan is offline
#0940 (Digital Demolition)
Cadetdan is an unknown quantity at this point
Send a message via MSN to Cadetdan
Ok well we burned up 2 more radio cables this morning. And now the RC is acting funny......it works but all the LED's are out. So yeah I dunno what went wrong but I guess ill have to send it to the US first people. What might have caused this? We never fool around with the RC we took it right from the box and put it on the bot! Aight well thanks for the help!!!!
Dan B........Yum Do I Smell Burning Rubber
Unread 14-02-2004, 17:29
dont send it to FIRST - you have to contact these people www.innovationfirst.com - its a separate company that makes the control system and sells them to FIRST
Unread 14-02-2004, 20:02
Let us know what the outcome is, please. With all the LEDs out and everything else having problems, I am still voting for a 5 volt regulator failure. That is bad news.
Unread 14-02-2004, 22:53
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Others have provided a lot of answers for you but I'd like to add a general guideline. If wires get hot enough to melt or burn, there's a major problem somewhere. Whenever this happens you should shut everything down, disconnect any power sources (like the battery), and start checking everything. Don't bother turning anything back on until you find a real problem that's been fixed, or you'll just burn up more wires (as you apparently found out).
Hope you find your problem soon!
Unread 15-02-2004, 03:41
tenfour's Avatar
tenfour tenfour is offline
AKA: Chris
#0696 (The Circuit Breakers)
tenfour will become famous soon enough
Send a message via AIM to tenfour
If the radio was working fine, it sounds like there is a problem with the system before it. I would switch the cable. Also check for type of conductor bridge between the pins and/or connectors. Just blow hard on the end. There could be some type of metal chip in there. If you have to, just return it and make hem ship it out next day. Good luck.
-2004 Arizona Regional Finalists (thanks 80 and 498)
-2004 Arizona Regional Sportsmanship Award
-2003 Los Angeles, CA Regional Finalists
-2003 Phoenix, AZ Regional Semifinalists
-2003 Phoenix, AZ Regional 3rd Seed.
-2002 Los Angeles, CA Regional Semi-Finalists
-2001 Los Angeles, CA Regional Semi-Finalists
FIRST Mantra - When Lawyer-ism fails, Gracious Professionalism Prevails.
(Yes, it is "BCR Orange")
Unread 15-02-2004, 03:51
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We had an edu motor with a little spec of metal shorting the two pins on the circuit board and it would not work at all. Then we removed the offending debris, and it now works great. Kind of similar.
Anyway yeah, the cable may be grounded to a common ground somehow, and if you have a power wire touching the ground somewhere, it may cause the problem. Also, shouldn't a breaker be tripping before wires start burning? I mean, that's what breakers are for right?
Unread 15-02-2004, 09:46
Sandrag,
This is another of those little inconsistencies in electronics/electrics. The modem is fed power from the RC which in turn is connected to a circuit breaker. Normally the power supply in the RC will limit the voltage and current being fed to the modem. The cable used to feed the modem may have wire as small as #30 which can only handle a fraction of an amp. If the modem-RC has some form of failure and more than a fraction of an amp flows, that is sufficient to heat the wire but not trip the circuit breaker. At some point the wires will begin to short together when the insulation has been comprimised and then the current gets high enough to trip the breaker. Since these are auto resetting breakers, the condition continues until the operators get tired of the smell and smoke and turn off the power to the RC/robot. There are also internal auto resetting breakers inside the RC. They replace the fuses used in the previous version of the RC. The current on the modem was fused for 0.5 amps in that version.
Fun Times at the Hardware Store sanddrag General Forum 10 19-03-2004 23:55
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
LEGO IR tower cable Jeff Rodriguez Chit-Chat 1 31-10-2003 16:23
Competition port cable Ken Leung Electrical 2 17-09-2003 08:12
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
