Go to Post Screws come even smaller, #0000 - 160 at Small Parts.They're about $4 each, and made by elves. - DonRotolo [more]
Unread 02-02-2004, 13:07
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: TEAM 1213 GROVES HS
Unread 02-02-2004, 13:12
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: pic: TEAM 1213 GROVES HS
What gear ratio are you using between the CIM and drill? Drill in low is at 450 rpm and the CIM is at 5000(?) rpm. This is greater than 10:1, not matching close will cause one motor to add inefficiencies to your system. Of course your robot looks pretty light right now so this is not a big concern right now.
As you add systems the inefficiencies will show up in battery drain. Possibly a big factor at the end of a match.
I love the picture of your robot climbing the cabinet! Add an anti-gravity unit and you will get up on top!
Andy Brockway
Team 716, The Who'sCTEKS
Unread 02-02-2004, 16:45
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Maybe the bosch will be locked into high? At least thats what the gearing would suggest. That is a very lightweight looking drivebase, always a nice thing to have.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 02-02-2004, 16:57
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Not sure if its the lighting, but that chain looks like it belongs on Mr. T's neck
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 02-02-2004, 17:07
Mike M. Mike M. is offline
insert custom title here
Mike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant future
it looks like a very driveable base but there doesn't look like there is much room to mount systems and other things
Gael Force 126 2003-2004 Mechanical, Pit Crew, Grady's #2
T-Hawks 1100 2005-2007 Mechanical, Driver, Coach
Rhodewarriors 121 2007 IRI Operator
PiraTech 2023 2008 Mechanical, Coach
Gael Force 126 2009-2010 Mechanical, Photographer
Current [RIDE] Volunteer Coordinator
Unread 02-02-2004, 19:17
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
I think that it is in high gear. Makes sense that way. They will have a FAST robot.
Anywho, check out their drill motor mount!
Already broken, thats gotta be a new record.
Get a new one or fix that one, your drive base looks great. Lightweight, FAST, durable (well, it looks durable, anyway). Compact. A good job.
Best of luck!
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 02-02-2004, 19:57
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
most likely they just locked the drills in high and turned down the voltage on the Chip to match rpms.
we have a prototype that is geared down at about 1:1.8 (i think) using the drills in high, and it goes somewhere around 13 or 14 ft/sec. assuming that the two out gears are a 22 and an 80 tooth (it's what they look like at least), that puts them at about a 1:3.6 or so. So, I'm guessing that with the chips added in, they could pull 8 or 9 fps. not blazingly fast, but certainly competitive.
looks good, although i will definitely agree with the comment you made in your other pic. there will be lots of bots flipped this year, especially with bots using the 12 inchers to climb the stairs. but they won't be flipping themselves on the stairs, they will be flipping themselves on other robots. unlike walls, robots push back. I can't count the number of times that i've seen robots with exposed wheels ride up on other robots and get flipped, even with extremely low centers of gravity.
You might want to consider putting a guard over one set of wheels. You don't need to be able to go up the stair with both ends, and putting a shield over one end will give you a surface you can use to push against other robots without worrying about flipping yourself over.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 02-02-2004, 20:04
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
are you able to turn easily. Bots the have tank drive and all pneumatics seem to have trouble.
2004 National Finalists with 469 and 868
2004 Gallileo champions and #1 seed
  • Delphi "Driving tommarows technology" -philly 2004
  • 8th seed philly 2004
  • 58/58 at annapolis 2004 (like the improvement?)
  • Philadelphia Alliance Regional Winner!-2003
  • 7th seed Philly 2003
  • Rookie all star philly 2003
  • semi finalist Pitt 2003
  • picked 3rd in pitt 2003
  • Seeded 17(curie) at nats 2003
Unread 08-02-2004, 01:34
groves groves is offline
Steve Liggett
None #1213 (Groves)
groves is just really nicegroves is just really nicegroves is just really nicegroves is just really nicegroves is just really nice
Yes, the gear ratio is 1:4 with a 12 tooth on the Chip, and a 48 tooth on the drill which is locked into high gear. it's very fast and turns beautifully! (the tires I think are perfect!) thanks for replying everybody! the driving sprockets are 20 tooth to a 60 tooth but i'm thinking about changing it to a 15 tooth to the 60 tooth to slow it down a bit. but its the coolest robot i've ever controlled. we do drain batteries really quick! boy those motors sure get warm! that little backup battery is very important.
Unread 14-02-2004, 11:02
Jay TenBrink Jay TenBrink is offline
FRC #0494 (Martians)
Jay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond repute
Nice and simple. I love it! We'll have the same layout this year only with 35 pitch chain and a third motor per side.
Check out the drive train from those national finalists the Goodrich Martians. You can see it on 494martians .com.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
