Go to Post I personally hope they change the terrain of the playing field ... if only to "level" the playing field. - Daniel_LaFleur [more]
Unread 14-02-2004, 14:11
thelastride thelastride is offline
no team (Iron Eagles)
thelastride can only hope to improve
Question where do we connect our motors for navigate.c
I have a question where do we connect our motors in what Pwm for the code navigate.c can anyone please tell me and our robot is 2 wheel drive. and we are currently using pwm13 and pwm 15.
Unread 14-02-2004, 14:38
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: where do we connect our motors for navigate.c
Isn't it documented in navigate.h?
-Kevin
Kevin Watson
http://kevin.org
Unread 14-02-2004, 20:39
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
pwms 13 and 15 should work if you are doing one-joystick drive. if you are using two joysticks for control, pwms 1 and 2 are the ones you want.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 15-02-2004, 13:01
Remember the navigate project doesn't come with a Default_Routine(), so you'll need to add one.
If you've added navigate to your default code then you need to change navigate.h "left_drive" and "right_drive" to match the pwms you are using (pwm13/pwm15).
Unread 15-02-2004, 15:33
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
what do you mean by the above quote i don't get it because we have a 2 wheel drive robot operated by one joysitck and we dowloaded navigate.c in our robot and it doesn't work the computer tells move to centre, turn to right.. don't know but it says something like that but our robot doesn't move although the programm is giving out command do you know why?
Unread 15-02-2004, 15:45
As I recall navigate.c by default expects the motors to be attached to pwm03 and pwm04.
If you are using navigate without any modifications then it waits at the start for someone to push the forefinger button on the joystick before starting.
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
