Go to Post I guess I'm a bit of an apple fanatic. - Austin [more]
Unread 14-02-2004, 16:08
Chaychay Chaychay is offline
AKA: Jay Shah
FRC #0610 (Crescent Robotics)
Chaychay is on a distinguished road
Send a message via MSN to Chaychay
IR senors detect pulses for 360 degrees
Hello,
Team 610 has hooked up their IR sensors, and they detect the pulses for 360 degrees. We took a 4 inch steel rod (3/4" thick) with a 1/2" hole threw it. We put the sensor threw the hole, and it still detects pulses for over 180 degrees.
Can anyone suggest what to do? (we tried other things before the steel rod)
We're stumpped.
Thanks in advance,
Team 610
Unread 14-02-2004, 17:06
Re: IR senors detect pulses for 360 degrees
the problem you are having is that the become light is very strong, and it will reflect off walls or people standing nearby, or any other nearby objects
so if you are trying to test them in a small room, then no matter which way you point the sensor or the beacon, it will flood the room with light and the sensor will trigger.
so first step is you gotta set the beacon up in an open space, like it will be on the playfield
then you have to put your sensor into some sort of enclosure - we found the little black hobbie boxs from radio shack work well. put the sensor in the box at one end, then drill a hole in the other, like a pinhole camera - the sensor will only detect when light enters directly through the hole and hits the sensor
depending on how big of a hole you put in the box, the sensor will act like a telephoto or wide angle lens - so start with a small hole and work your way up.
If you dont want the sensor to be too angle sensitive in the up/down direction then instead of a hole, cut a slit in the one end
BTW - we tried playing around with metal and PCV pipe to do this. The metal reflects the light too well inside the pipe, so its not directional, and the PCV has the same problem.
Unread 14-02-2004, 17:10
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
the most important thing is defently the vertical slit and a non reflective material
Unread 14-02-2004, 17:19
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Basically, you are making a light trap. Covering in the inside of the project box with black flocking paper (or black felt) will help, especially if the inside is originally smooth plastic.
Zan Hecht
Unread 14-02-2004, 18:24
Kevin Watson's Avatar
La Cañada High School
FRC #2429
From the FAQ:
Q: We've assembled everything and it works pretty well except the infrared trackers are tracking beacon reflections off of reflective surfaces. What do we do?
A: You think like an engineer and find a creative way to solve the problem. Didn't you see the flawless demonstration performed at the kick-off? If so, you know it can be done.
Q: Okay, we're four weeks into the build and we're spazing because we're too wired on Mountain Dew, not getting enough sleep and we really don't need flippant answers like the one above. So what's the deal with reflections? Don't make us come over there and steal the plastic pink flamingos from your front yard!
A: <sigh> Okay, If the sensors rotate in a plane that includes the beacon, the tracker will work just fine if it can't see (reflections) above or below that plane. Our original prototype looked like a side-by-side shotgun mounted to the servo. Imagine looking through a long, dark piece of tube while you slowly spin around a dark room that also has a friend holding an LED flashlight at the same height as the tube. As you spin around, what are the chances that you'll see a reflection off of any surface? Pretty slim because the point of reflection must also reside on that idealized plane. The chances are also made even slimmer when you realize that not only does the point of origin have to reside on the plane, but the photon must also pass through one specific spot on the plane: your eye.
We found this setup to work pretty well until the servo had to try to keep up with a moving target. So we had a minor epiphany and realized that if we cut a slit down the tubes such that one of the sensors would always have a view of the beacon, we would always know which direction to move the servo to catch up.
Q: I still don't think it's going to work because when I fire-up the beacon in my bedroom, the tracker still sees reflections from the walls, the carpet, and my chihuahua.
A: Okay, I know it's convenient to build and test gizmos in one's bedroom, and instead of driving out to the desert, I would love to bring home the odd prototype Mars rover for testing in my bedroom, where I'm near an ample supply of Diet Pepsi and tools. Sure, it makes a lot of sense to design and initially test stuff in the lab (or bedroom), but before you make a final judgment on how well your gizmo works, you've got to test it in it's intended environment, which, in this case, is a FIRST robotics playing field. Here are a few of the differences:
1) When your bedroom was built, I'll bet that little thought was put into the suppression of infrared beacon energy. Update: Okay, so a few of you do have infrared energy-suppressing bedrooms. Please stop e-mailing me because you're creeping me out.
2) The ambient light level is too low for the amount of infrared energy that's being transmitted. The infrared sensor has a built-in AGC (Automatic Gain Circuit) that greatly amplifies the output of the infrared photo diode when the noise level (ambient light) is low. With the gain on the amplifier cranked-up, the sensor is going to be able to sense (and react to) the faintest reflection. Add to this an infrared beacon designed to blast enough energy to fill a full-size 48' x 24' playing field and it shouldn't be any wonder the the tracker tracks your chihuahua. Either reduce the amount of transmitted energy with a filter, increasing the value of the current-limiting resistors, etc. or increase the amount of ambient light in the room. As an example of just how well these sensors can detect the infrared beacon, while testing the receiver code, I setup a beacon LED next to a very bright flashlight and had no problem tracking it from a foot away or across the room. For extra credit, at night, fire-up the beacon in your bedroom after turning-off the lights, duct-taping the cracks around the door(s), etc. Pretty dark, right? Now, turn-on a camcorder or digital camera that has a LCD viewfinder. Unless, your camera has a built-in infrared filter, you should see the room through the viewfinder as thought it were dimly lit. This is how the sensor "sees" your room.
3) Your bedroom probably isn't the size of the Georgia Dome. The chances of a reflection making its way back to the sensor with enough energy to be detected, is reduced in large spaces because of the inverse square law of light brightness, which states that the amount of light energy deposited on a fixed area is inversely proportional to the square of the distance traveled. As an example, the reflection off the bulb in your bedrooms table lamp has on the order of one-hundred times more energy than one returned from the bulb in the fixture on the ceiling of the Georgia Dome.
Q: We noticed that the sensor can sometimes detect the beacon even when the little window isn't pointed at it. Is this a problem?
A: Yes, I can see where you might think the little hemisphere window is where the infrared light must enter to be detected. Actually, the entire epoxy package, that the sensor is embedded within, is transparent to infrared light. I've noticed that unless I shield everything except that window, the sensor will detect the beacon from just about any angle. This is why you'll see the sensor in my example tracking assembly is covered by dark gray heat shrink tubing.
-Kevin
Kevin Watson
http://kevin.org
Unread 14-02-2004, 22:45
AKA: Jay Shah
Wink Re: IR senors detect pulses for 360 degrees
Thanks a lot everyone!
I will try all those suggestions ASAP,
Thanks Again!
Team 610
Unread 15-02-2004, 15:06
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Hello,
We're stumpped.
Thanks in advance,
Team 610
Try using a non-reflective substace for your 'binders'
I think whats happening is that any pulse that can get into your steel tube just bounces off the walls until it reaches your sensor. Use black non-reflective plastic or something.
I've heard that heatshrink (wire wrap) works very well, also.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Official Beacon Tracking Code Posted Kevin Watson Programming 41 18-02-2004 21:04
