I have a question where do we connect our motors in what Pwm for the code navigate.c can anyone please tell me and our robot is 2 wheel drive. and we are currently using pwm13 and pwm 15.
Re: where do we connect our motors for navigate.c
-Kevin |
pwms 13 and 15 should work if you are doing one-joystick drive. if you are using two joysticks for control, pwms 1 and 2 are the ones you want.
If you've added navigate to your default code then you need to change navigate.h "left_drive" and "right_drive" to match the pwms you are using (pwm13/pwm15). |
If you are using navigate without any modifications then it waits at the start for someone to push the forefinger button on the joystick before starting. |
| PWM and burning out motors | patrickrd | Technical Discussion | 7 | 19-06-2003 15:30 |
| Looking for practice motors & extra tape drive parts? | archiver | 2000 | 1 | 23-06-2002 22:54 |
| Suppose you want seat motors... | archiver | 2000 | 0 | 23-06-2002 22:50 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Drill Motors | TF8 | Motors | 19 | 12-12-2001 13:13 |
