Go to Post To quote Harrison Ford: "Never tell me the odds". - [more]
Unread 14-02-2004, 19:40
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
Boolean statement
simple question, in an if statement is a value of 0 = to false or to i need to say !variable==0 to get false( or variable==1). not too important it will just save me time in writing the code and i dont want to go back and have to fix it.
Unread 14-02-2004, 20:00
kiracofe8 kiracofe8 is offline
#1317 (Digital Fusion)
kiracofe8 will become famous soon enough
Re: Boolean statement
int x = 0;
if (x)
//this code never executes
else
//this code always excutes
However, in C, I would consider it to be good coding practice to explicitly write the test as:
if (x == 0)
// stuff
else
// other stuff
or even
if (x != 0)
//other stuff
else
//stuff.
/* Daniel */
Unread 15-02-2004, 07:31
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Just to clarify what he said, in C any non-zero value is true. Zero is false. So, if you had a variable and you wanted to test if it was zero, you could say:
    if(!variableBeingTested)
    	// Variable is zero
    else
    	// Variable is not zero
It is considered better form by most people, however to explicitly put in the test for zero. For example:
     if(variableBeingTested == 0)
     	// Variable is zero
     else
--EDIT--
PS I just looked at the last post guy's name and team number and realized he's one of my team's mentors.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Mission Statement Madison FIRST-related Organizations 11 19-05-2003 14:54
Help w/ a Research Paper concerning a Dean Kamen statement Ryan Dognaux Chit-Chat 1 10-02-2003 22:55
Varying levels of enforcement... Gui Cavalcanti General Forum 9 28-03-2002 16:29
Improving PBASIC: Request for Comments Greg Ross Programming 19 16-02-2002 22:14
