Go to Post This year it is what it is and, at some point, we will all find out what that is, specifically. - JaneYoung [more]
Unread 15-02-2004, 08:28
clynch clynch is offline
clynch is an unknown quantity at this point
'Program State' LED stays blinking yellow after download
Our '2004 FRC Robot Controller' is having trouble running the default hex file (or any hex file). After downloading via IFI Loader v1.0.7, the 'Program State' LED stays blinking yellow. Shouldn't that LED turn green following download?
-clynch, 487
Unread 15-02-2004, 08:39
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: 'Program State' LED stays blinking yellow after download
-clynch, 487
For the program to actually start running (and the LED to turn green) the OI must be turned on and in contact with the RC, either through the tether or the radio. My guess is you don't have the OI turned on/close enough. Hope that helps.
Unread 15-02-2004, 12:31
i had the same problem. What you need to do is
1)hold down both the program and reset buttons.
2)Then, let go of the reset button. (The power light will be blinking green. )
3)Wait until the green light is solid.
4)Let go of the program button.
Now, the power light should be solid green and the prgm button should be solid orange. This is the time to download the code. Then after that, hit reset again.
PS.. that is probably one of 1000 ways to get it to download, but i seems to be the method i have most luck with.
Unread 16-02-2004, 13:58
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
rwaliany will become famous soon enough
Simple solution. If it is blinking yellow after you programming it, chances are you just don't have your operator interface hooked up. The programming was still most likely a success. All you have to do now is reset the RC then it should be programmed. To get rid of a yellow blinking light after you program and to allow the reset command the operator interface must be tethered or communicating via radio.
Thanks,
Ryan Waliany
R
Unread 16-02-2004, 22:04
Yes, it was a missing OI. Thank you all.
clynch
Unread 18-02-2004, 19:34
mightywombat's Avatar
mightywombat mightywombat is offline
bins? stacking?? NOOOOO!
AKA: Bill Rosemurgy
#0857 (Superior Roboworks)
mightywombat is on a distinguished road
Hey.
We have had the same problem. I haven't had the time to try to fix it as it happened to us today and I'm just finding the answers...
One extra question that I have is:
Does anyone know how to prevent this? Or what causes it?
Bill Rosemurgy - Aspiring Programmer and Human Player (stack of 8 in <10 seconds...oh yeah... but I can't shoot for crap.)
www.team857.com
FRC Program State Frozen at Power-up WillyC Control System 4 14-02-2004 18:05
RC program state problems Max Lobovsky Programming 3 14-02-2004 15:02
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Anyone looking for more program space? archiver 2001 13 24-06-2002 02:20
