Go to Post So as you're thinking about this, think simple. - Cyberguy34000 [more]
Unread 15-02-2004, 10:00
aaronbr28040's Avatar
aaronbr28040 aaronbr28040 is offline
AKA: Aaron Bradshaw
#0900 (Team Infinity)
aaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really nice
Send a message via AIM to aaronbr28040
Re: Tapping broken taps (a.k.a. I'm all tapped out)
Lots of holes tapped this year and no broken taps so far......but I'm keeping my fingers crossed. Nothing can beat some TAP Magic Aluminum and some patience.........(staying up till 1:40AM tapping the frame pieces one night). Thanks for the tip Dave. Your storieis and tips are always so helpful and entertaining to read.
@North Carolina State University
Team 900
North Carolina School of Science and Mathematics
AIM:aaronbr28040
Unread 15-02-2004, 12:04
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Alum is used to make pickles, and is also available at food supply wholesalers if you are willing to buy 10 pounds at a time (you just want to dissolve the steel parts from your little brother’s bicycle).
That really must be some potent pickles. Though I wonder how those people found that out. Opps I droped my tap in grandma's pickles.
Unread 15-02-2004, 12:52
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
$@#$@#$@#$@# i wish i knew that before. we broke to taps in out shafts and only had enough to replace one. i was so POed that i took it to a grinder and still couldnt find the bottom.
BTW would this meathod be safe on the axel shaft that comes in the kit??
Unread 15-02-2004, 13:05
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
My guess is that it would ruin the shaft and eat it away as well.
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 15-02-2004, 13:31
Matt Spencer
AKA: Sexy Beast
thats what i was afirad of
Unread 24-06-2004, 14:11
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
I tried your method and failed! But perhaps I got something wrong...
I first broke a standard 4-40 tap in a 0.092" aluminum hole (actually one of my teammates did).
Then I was excited to finally have the opportunity to use alum and dissolve the tap. Since the part was quite small, I filled up a pepsi can (with the top cut off) with boiling water, and added in about a teaspoon or tablespoon of alum. I then mixed it up, threw in the part, and waited. When I came in today (after a full night of the alum doing its thing), I couldn't get the tap out, and it still seems to be the same as it was.
So, I'm thinking of two possible errors:
1) I didn't put in enough alum (what are the correct proportions of alum to water?)
2) The water quickly cooled to room temperature... Maybe I should keep it boiling like the instructions say.
Any input would be appreciated!! Thanks!
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Unread 24-06-2004, 15:03
Elgin Clock's Avatar
FRC #0237 (Black Magic)
NIce tip. I'll have to remember that for next year.
Anyways, speaking of cool metal related tips and tricks, does anyone have a good way to remove rust and corrosion from nuts and bolts, or large pieces like car body panels - in case you do want to finally take a chance at fixing up that '68 Chevy Engine that is sitting in your living room - (or '79 Mopar 360 as it may be in my case).
I was thinking just buying a cheap barrel tumbling kit from the craft department of the local store for the nuts and bolts, but will that work?
Is there a chemical way to remove rust and corrosion that would be faster, or easier - more for the bigger parts that won't fit in a tumbler?
I don't mind using a little (or a lot) of elbow grease, but if I can just let things get clean overnight in a solution of whatever, or in a barell tumbler, then that would be great.
Unread 24-06-2004, 15:57
Lisa Perez's Avatar
Lisa Perez Lisa Perez is offline
FRC #0573 (Mech Warriors)
Lisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond repute
Carbonated drinks are supposed to be able to remove rust and corrosion.. but I haven't been able to test it out yet. The CO2 is supposed to react with the oxide that forms the rust, thus restoring the metal to its original state.
Event Coordinator - Center Line District Event
Volunteer Coordinator - Michigan State Championship
Lead Mentor - Team 573, Mech Warriors
Former Mentor - Team 830, Rat Pack and Team 3182, Athena's Warriors
Proud Alumna - Team 573, Mech Warriors and Team 1, Juggernauts
Unread 24-06-2004, 19:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I saw this thing on a show called Trucks! that was like a big bowl of nut shells or something and it vibrates a lot and you put your parts in there and they come out real nice after like a day. I think it was pretty expensive though.
Unread 24-06-2004, 20:23
Adam Y.'s Avatar
Adam Y.
no team (?????)
There was an episode of mythbusters that tested all the differnt myths related to colas. I don't remeber the results though.
Unread 24-06-2004, 20:56
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
if i recall corectly, soda does remove rust and grease (to an extent) but not as well as rust and grease removers
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 24-06-2004, 21:26
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
The truth behind this "urban myth" is the soda doesnt remove the filth, its mainly one ingredient in the soda that wil clean filth. This main ingredient is Carbon Acid. When you try to clean with soda, you gave the sugars, dyes, additives and syrups that will go onto what you try to clean and thus its dirty once again. When you use plain carbonic acid or really old soda (where the ingredients have broken down and carbonic acid is still there), you will get a clean surface and it will help prevent future deterioration. So if you are looking at cleaning it with a "soda bath" i would reccommend going to a beverage distributer and seeing if they have any plain carbonic acid that you could purchase. Other wise i would suggest you going a different route and first try a pressure washer with a degreaser or cleaner.
-Michael Dessingue
Unread 24-06-2004, 21:33
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
So carbonated water is the best bet?
Unread 24-06-2004, 21:16
AKA: Jamie Bliss
An ultra sonic cleaner. Usually used with jewely.
The problem with mechanical means of removing R&C is that you actually remove material. They won't fit together as well any more.
Unread 25-06-2004, 15:46
UCGL_Guy's Avatar
UCGL_Guy UCGL_Guy is offline
AKA: Ken YorK
None #0476 (Wildcats)
UCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to all
Send a message via AIM to UCGL_Guy
You can still find places that "Hot Tank" parts for you - which depending on your part is either an acid bath or caustic. I had an engine block done about a month ago. Saw an episode of "Overhaulin" wher they acid dipped an entire car. Galvanizing places usually have a huge hot tank.
For home use there is Naval Jelly - been around for years and works pretty well. For bolts and small parts I use a grinder and a wire wheel, these throw off the bristles pretty well so make sure you wear a face shield.
But the best is a sandblast cabinet and is enviromentally friendly.
Word of caution when using chemicals of any kind. Make sure you know the hazards before you proceed. Look up the MSDS for that material on the internet or find an expert ( and then check the expert to make sure they told you right). Acid and Bases can create strong exothermic(heat releasing) reactions.
Ken
Ken York
Mentor/Coach Team 476 Ponca City OK
An ignorant person is one who doesn't know what you have just found out.
Will Rogers
