Go to Post That's co-oper-tastic. - anyheck [more]
Unread 14-02-2004, 15:37
great_one411 great_one411 is offline
#1210 (NYACK)
great_one411 is an unknown quantity at this point
Question Modifying Default code
How do you modify the Default Code from one joystick to two joysticks
Unread 14-02-2004, 15:55
Re: Modifying Default code
[edit] Forgot the rest of the story. This goes in Default_Routine() in the user_routines.c file. Comment out the 1-Joystick lines:
//pwm13 = pwm14 = Limit_Mix(2000...
//pwm15 = pwm16 = Limit_Mix(2000...
and add in
/*------------ 2 Joystick -----------------*/
pwm13 = pwm15 = p1_y;
pwm14 = pwm16 = 254 - p2_y; // Assumes your motors are reversed, just p2_y if not
Unread 15-02-2004, 08:58
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Basically what he said, just simplified. To map two joysticks, you would do something like this:
// This code assumes the joystick are on ports 1 and 2 and pwm01 and 02 are the drive motors.
// These can be easily changed
pwm01 = p1_y;
pwm02 = p2_y;
That code just makes the Y axis of the joysticks on ports 1 and 2 run the left and right drive motors.
Unread 15-02-2004, 09:44
The default code already has two joystick drive on pwm01 and pwm02. You just need to change pwms. No code changes necessary.
Unread 15-02-2004, 12:44
Depends on which copy of the default code you're working with.
IFI dropped the 2-joystick code from later versions.
Unread 15-02-2004, 13:00
I know it was in the first version posted, and its also in the current version (2-10-2004). I haven't used any intermediate versions, but I find it hard to beleive that Innovation FIRST would have dropped it.
Lines 211 and 212 (in Default_Routine)
  pwm01 = p1_y;
  pwm02 = p2_y;
Unread 15-02-2004, 13:02
Programming User
I just thought the example without all the extra stuff would be helpful.
Unread 16-02-2004, 10:32
 pwm01 = p1_y;
pwm02 = p2_y;
I looked right past the obvious!
I believe at one time (maybe EDU code) they had the line:
/*---------- 2 Joystick Drive ----------------------------------------------
and that's what I was missing.
Thanks!
default code and the actual robot tml240 Programming 15 24-01-2004 11:31
How long does it take you to load the default code? vegasmcse Robotics Education and Curriculum 10 03-11-2003 21:41
2003 PBasic default code from Innovation First ttedrow Programming 0 06-01-2003 11:18
default code archiver 2001 2 23-06-2002 22:53
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
