Go to Post The flux capacitor should have been allowed under the flowchart as long as it met the single component maximum cost. I did check with Digikey and they no longer carry the line. - Al Skierkiewicz [more]
Unread 15-02-2004, 15:37
ErichKeane ErichKeane is offline
FRC #3210
ErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really nice
Send a message via AIM to ErichKeane
Distro block, maxi fuse box, and ground stem
3 Questions:
1 We misplaced our 40 amp maxi fuse box, so we purchased the stinger 3 sided one, is this ok?
2 Right now, we dont have either the weight, nor the ability to use the ground stem, so we are using the ground block on the mini fuse box (for 20-30 amp fuses). is this also suficcent?(and legal?)
3 We lack both weight space and product to use the Distrobution block included in the kit. So we have the breaker split wire to the Maxi and mini fuse box seperately. i could find nowhere where it posted the distro block as a requirement, does anyone know betteR?
thank you all.
