Go to Post Tell the truth - that's really a small barbecue grill on that robot isn't it. - Tom Line [more]
Unread 15-02-2004, 13:45
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
Double Solenoid Wiring
im wondering if i can hook both sides of the double solenoid to the same spike in oposit sence they seem to be mutually exlusive.
Unread 15-02-2004, 14:41
Re: Double Solenoid Wiring
what you can do is hook up one side of solenoids Positive wire to the relay FWD output. Hook up the negative wire to ground. Do the same with the other side of the solenoid, just to the relay REV output. Then in your program you will be able to open and close your air pistons by setting buttons to relayx_fwd and relayx_rev.
Unread 15-02-2004, 15:35
occra 23.
AKA: ryo
None #1481
actually, there is a manual on first.org under robot in the manuals...
aha, <a href="http://www2.usfirst.org/2004comp/5-TheRobot-RevA-markup.pdf">here on page 16 (5.6.3 relay modules)</a>
umm....how do you place a URL if you can't use tags? anyone?
Unread 15-02-2004, 15:43
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
the way ive found works best requires 4 diods.you hook the postitves from each one up to inversly facing diodes to the o+ and the ground to the o-. this way you can never trigger both at the same time.
"You're not a real programmer until all your sentences end with semicolons;"
Unread 15-02-2004, 16:27
Matt Spencer
AKA: Sexy Beast
are the diodes nesseccary if programed corectly?
ie turn off one before turning on the other.
sence the point of the diodes is to prevent them from going at the same time it would seem a good program could do the same....i dont feel like making another time waisting trip to radio shack.
Unread 15-02-2004, 16:44
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
The diodes are necessary for blocking if you wire the double solenoid valve in this configuration. There's a diagram in the manual that shows you how to do this; it's simple and inexpensive, and it's definitely worth the extra effort.
Incidentally, does anyone know if it's legal to connect a pair of single solenoid valves using this method?
Unread 15-02-2004, 21:37
AKA: theshadow
FRC #0620 (WarBots)
yeah i see no reason why you shouldent be able to wire up 2 single's with one spike. just put the diodes in a box
Unread 09-10-2004, 23:55
Kautz Kautz is offline
#1008 (Lugnuts)
Kautz is on a distinguished road
Will this work using the new Festo double solenoid and using the doides and one spike?
Willian F. Kautz
Team 4145 ,1008 and 3262
Retire Teacher
Columbus City Schools
Columbus,Ohio
Festo solenoid wiring? computhief263 Pneumatics 1 15-02-2004 12:25
using single solenoid like a double SteveO Programming 14 02-02-2004 22:51
Anyone willing to trade (something they need) for the SMC double solenoid? Jeremy Kit & Additional Hardware 0 27-01-2004 20:14
multiple cyclinders from one double solenoid Ed Crammond Pneumatics 1 07-02-2003 18:49
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
