Go to Post And Dave, although I know you have connections, please don't slow the earth's rotation to get more time on the caption contest. ;) - Billfred [more]
  #31   Spotlight this post!
Unread 18-01-2004, 13:02
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Using Digi-Key Shaft Encoders
Originally Posted by WizardOfAz
Hmmm. I'm not going to dive into the details of this I guess, since I'm going to continue down the "pot path" for measuring the angle. But I suspect this calculation is more than a bit optimistic. (1) can you really handle the shaft encoder interrupt in about 10 instructions? (2) are all instructions one cycle with no wait states needed? (3) what about the state save/restore cost of the interrupt? I'll bet it's more like 1% than 0.1%, still not too much load if you don't have a lot of them.
It's 40 or 50 instructions total. There are no wait states involved.
-Kevin
Kevin Watson
http://kevin.org
  #32   Spotlight this post!
Unread 22-01-2004, 17:49
IrisLab's Avatar
IrisLab IrisLab is offline
AKA: Dave Page
#1466 (Webb School)
IrisLab will become famous soon enough
I'm having trouble with the links to digikey at the first of this post. Does anyone know the part numbers that the links refer to?
Or alternatively, any recommends for digi-key optical encoders?
Thanks.
David Page
  #33   Spotlight this post!
Unread 15-02-2004, 15:10
Joel J's Avatar
Joel J Joel J is offline
do you..
Originally Posted by Kevin Watson
If you really, really want to use a potentiometer, why not use the Bourns 6639S-1-103 which is available at Digi-Key (search for 6639S-1-103-ND). I'd rather use an encoder.
-Kevin
I am in heavy deliberation at the moment. I am trying to decide whether or not I wish to use a potentiometer or encoder for something relating to the subject of this thread. I am pretty much at a loss for good reasons (I have never used potentiometers or encoders before), so I am wondering why you have a bias that steers more towards an encoder than to a potentiometer.
Joel Johnson
RAGE (173) Alumni, 1999-2003
  #34   Spotlight this post!
Unread 15-02-2004, 16:48
D.Viddy's Avatar
D.Viddy D.Viddy is offline
AKA: Dylan Vester
FRC #3176 (Purple Precision)
D.Viddy is an unknown quantity at this point
Because almost all potentiometers that will find will not revolve all the way around. Also pots wear out very easily when attached to a constantly rotating shaft. Last years controller was too slow for using an encoder. This years processor has no trouble keeping up with a 256 tick encoder. We have ours controlling our motors beautifully right now. Dead recoding is incredably precise with them. It's not a bias, it's just one is better than the other.
Dylan Vester - (Programmer)
Running a P4 1.8 Ghz
Team 998, We can't win...
  #35   Spotlight this post!
Unread 15-02-2004, 17:08
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
-Kevin
I have written my own Interrupt handler for reading the optical encoders. Is there an easy way to see how many instructions the C Code translates to?
  #36   Spotlight this post!
Unread 15-02-2004, 18:00
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
In MPLAB IDE, go to View->Disassembly
  #37   Spotlight this post!
Unread 15-02-2004, 22:56
FRC #2429
Yes, there certainly is. Have a look at the .lst file that the compiler generates. It's a text file that shows you what assembly and machine code the compiler generated and where it placed it in memory.
-Kevin
Kevin Watson
http://kevin.org
  #38   Spotlight this post!
Unread 16-02-2004, 00:47
Joel J's Avatar
do you..
Ok, thanks.
Joel Johnson
  #39   Spotlight this post!
Unread 16-02-2004, 03:34
FRC #2429
As Dylan and others have pointed out, potentiometers have problems when used for positioning/control. Encoders, on the other hand, are designed for this type of application. You can find some example encoder code here.
-Kevin
Kevin Watson
http://kevin.org
  #40   Spotlight this post!
Unread 02-03-2004, 15:21
Greg Powers Greg Powers is offline
#0814 (MegaForce Squadron)
Greg Powers is on a distinguished road
mechanical or optical encoders? i know the mechanical encoders are alot cheaper and i was wondering how much that degraded quality
does anyone know the pro's con's between the two?
we plan on using them to compensate for steering problems and atonomous and aren't sure which we want.
Sincerely,
ME
  #41   Spotlight this post!
Unread 02-03-2004, 19:28
Mechanical encoders don't last nearly as long as optical ones do - check the specs on them for that measurement.
  #42   Spotlight this post!
Unread 07-03-2004, 00:41
Daniel Daniel is offline
Daniel Katanski
#0240
Daniel is on a distinguished road
Have you read the white paper titled "Quadrature Encoders"?
This should help you a lot. email me if you have any specific questions or comments.
Daniel
  #43   Spotlight this post!
Unread 01-01-2005, 20:06
sudeepr71 sudeepr71 is offline
FRC #0503 (Frog Force)
sudeepr71 is an unknown quantity at this point
Send a message via AIM to sudeepr71
After reading this forum, I still have a few questions.
What exactly is a encoder?
And how can I use it to measure the speed of the robot?
  #44   Spotlight this post!
Unread 02-01-2005, 14:49
There are a few different kinds of encoders. What most people here are talking about are "rotary shaft encoders", which can tell you the angular position of a rotating shaft. Usually that's done by counting pulses as it turns. Some encoders have thousands of steps per rotation, giving a very precise measurement. At the other end of the precision scale, last year's TechnoKat robot used six black stripes on the wheel hubs with Banner sensors to measure wheel rotation.
To measure the speed, you just use the difference in position between two measurements at different times.
  #45   Spotlight this post!
Unread 02-01-2005, 19:16
On your last year's robot you used it to see how far to go and then turn or something for the autonomous mode? We tried that and found that it wasn't as accurate as the line following.
So to find the speed, one would have two encoders at different times and subtract them?
If set screws suck . . . Madison Technical Discussion 17 22-12-2003 19:19
Who used wheel encoders CyberWolf_22 Technical Discussion 12 04-05-2003 15:37
Where to get shaft encoders D.Viddy Programming 12 17-01-2003 09:38
Motor coupling archiver 2001 19 23-06-2002 23:35
Need Help on Shaft Mounting... archiver 2001 3 23-06-2002 23:29
