Go to Post you must do whats best for the company...not yourself. - Greg Perkins [more]
Unread 15-02-2004, 17:46
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Speed Controller brake/coast setting
Is it possible to control the brake/coast setting on the 884s with the digital out pins? I didn't want to try anything, as I believe a 1 is +5v. Will I damage anything by using this to select between brake and coast on the fly?
Thanks,
Steven
Unread 15-02-2004, 18:45
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Speed Controller brake/coast setting
I have no idea about the actual anser to your question, but when don't you control it with a relay? I'm fairly certain that would work, though not a spike relay.
I say get a miniature 5V relay, hook the coil up to the digital output, and hook the other side up to the brake/coast jumper. I'm assuming this will work, except I have no clue how much current the digital outputs can supply on the signal pins. Or even if that's how they work. IFI doesn't have much information on digital outputs on the website. The realy should work, however, as FIRST talks about using a microswith to control the brake/coast setting.
Unread 15-02-2004, 19:56
I dont know the correct answer, but I would not connect them to the digital output pins
try searching the forum, im sure someone has done it before - seach on 'victor brake' and see what comes up
Unread 15-02-2004, 20:43
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
A dip relay would do the trick for the "jumper" side, The current the coil draws is a published thing and a long time ago they were avialable from Digi-key. I would talk to the folks at Innovation First If the digital outs can sink the current. If you get dip relays get the ones with internal diodes, without diodes, the back emf can fry things, else put a diode as clsoe to the coil wireing as you can. If all is a go in terms of the rules you may have to use a driver transistor to keep the current to what the controler can do, OR Use a spike with diodes like called out in the <5.6.3> to drive two relays and avoid the whole asking permission about hooking directly. Also the information you seek may be in the user guide for the full size controler. Good luck
Unread 15-02-2004, 20:59
if the rules allow it, the easiest thing to do would be to have a contact switch that you close with one of the little servos they gave us.
Unread 15-02-2004, 21:02
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
yeah and if your not into servos and contact swiches.... just get a 5v dpdt relay, hook it up to (1) digital output and *vwala* perfect switching. the Victor 884 uses a pic microprosseser to control the fets in the HBridge, and its not going to be exsessive current at all. just remember to put it all in a box
"You're not a real programmer until all your sentences end with semicolons;"
Unread 15-02-2004, 21:54
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
The officially-sanctioned method, as suggested by IFI in the Victor 884 User's Guide, involves using servos and SPDT switches. I'm not sure if there are other methods that would be safe and successful, but that seems to be the one they encourage.
Unread 15-02-2004, 21:59
AKA: theshadow
FRC #0620 (WarBots)
okay.
servos are $30 bucks each. relays are free.
servos and switches are exsesivly prone to failure.
servos eat up power...
servos are huge compared to relays.
with all that said, yes its the "offical" way to go. will our team do it? uh no
Unread 15-02-2004, 22:05
#0246 (Overclocked)
I'm not saying that other methods are wrong. I'm just saying that the servo method is the one suggested by IFI.
For the record, you can draw 1 ampere total from all of the analog output and digital I/O Vcc pins. If you're not powering a lot of other stuff from those, using small relays should be fairly safe.
Unread 15-02-2004, 22:47
The suggested method is one we have used over the years. A servo with the cross attachment is mounted in such a way that when it turns it bumps into a microswitch that is wired across the brake pins on the speed controller. Controlled from software the servo either closes the switch or opens it.
Unread 15-02-2004, 23:09
The servo method does have one thing going for it. The servo should stay in position after power is cut to your robot. I think. I'm not an electronics guy on the robot, but if the power to the servo gets cut then it will definitely stay in position.
Unread 15-02-2004, 23:19
where do you get these free relays from?
I will take 10 million please :c)
if you are talking about the relay spikes that are in the KOP - you cannot use those to control the brake pins - the spikes put out 12V switched plus or minus, and they need power on their input (+12V) to work. they dont get their power from the PWM cables.
Unread 16-02-2004, 01:18
#0246 (Overclocked)
Yes. Wiring a Spike to the brake/coast jumper on a Victor would probably cause an unwanted release of magic smoke. If you intend to use something to control the jumpers for the Victors that drive your robot, then you'd probably be switching both at the same time and would only need one servo. Controlling the braking mode of your speed controllers with a servo and a pair of microswitches is a lot cheaper than destroying them by feeding 12 volts to the I/O lines of the speed controllers' logic circuitry.
Unread 16-02-2004, 02:27
telkanuru's Avatar
telkanuru telkanuru is offline
Generic Carbon Unit
#0246 (Overclocked)
telkanuru is an unknown quantity at this point
Send a message via AIM to telkanuru
I forget, do servos requre spikes? 'cause that would just be lovely in a painful sort of way.
Unread 16-02-2004, 02:30
#0246 (Overclocked)
No. They are powered by the Robot Controller and accept a signal directly from a PWM port.
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
Speed controller fan replacement Rickertsen2 Electrical 11 16-01-2003 08:46
Speed Controller Limits yaman Technical Discussion 11 15-01-2003 18:40
Ugh...PWM pin vs. Speed Controller archiver 2001 1 24-06-2002 00:27
making speed controller digital CharlieWilken Electrical 4 01-03-2002 20:15
