Go to Post I heartily applaud FIRST for finally reacting proactively to this ongoing problem. - Ether [more]
Unread 15-02-2004, 18:20
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Magic wheels
Re: pic: Magic wheels
wow... that looks pretty cool
Unread 15-02-2004, 18:25
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
If you come to Saint Louis regional, we will give you some little marbles. For free.
You see, to get the big ones (on a short notice without having to get them shipped) you have to buy a package of marbles that contains 300000 little ones and 2 or 3 big ones.
So we have a ridiculous amount of small marbles left over.
The wheel was made like this: we put marks every inch on the wheel, drilled in with a 1/4" hand-held drill, used the press and a 7/8" bit to make the hole, rubber-malleted a 1" marble into the hole.
No glue or epoxy as of now, although it may be added later. We are still undecided, although we are leaning towards "no."
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 15-02-2004, 18:51
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
Magic wheels
I don't know if you guys looked at this:
<R13>
In no case, will traction devices that damage the carpet or other playing surfaces be permitted. Traction devices may not have surface features such as metal, sandpaper, or hard plastic studs, cleats, or other attachments.
I know it doesn't say anything about glass or marbles but I think that would be up for interpretation. I would ask FIRST before I showed up to a competition like this.
Unread 15-02-2004, 19:00
rangersteve rangersteve is offline
AKA: Steve
FRC #0931 (Perpetual Chaos)
Team Role: Student
rangersteve is on a distinguished road
Send a message via Yahoo to rangersteve
uummm
if those are there to give traction then you might have a problem. Glass marbles aren't exactly sandpaper. I have a lot of concern for the design. I guess I'll find out at the St. Louis regionals. See you there.
Unread 15-02-2004, 19:06
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
It's a cool design but I doubt it will pass inspection. You do realize the edges of the platform are diamond plate and the spinning wheel will probably shatter or chip the marbles when it comes in contact with the diamond plate. FIRST won't be too keen on having to bring out an Electrolux and vacuum the field after your match. If you REALLY want to try to use these wheels I would suggest bring another set of wheels without marbles so in case you fail inspection you could change wheels.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
#1067 (SLUH)
Re: Magic wheels
<R13>
The rule is to prevent carpet damage.
Those marbles will not damage the carpet. They slide, thats what they are there for. I think the hard plastic studs refers to object designed to dig in and stay put: these exist to make the wheel easy to slide around. Our back rubber wheels do more damage to carpets that the marbles. I don't forsee a problem.
Unread 15-02-2004, 19:21
Mike M. Mike M. is offline
insert custom title here
Mike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant future
Re: Magic wheels
damaging the carpet is probably not going to be your problems but the problem will be that FIRST will not want to clean it up after every match. if those marbels break
Gael Force 126 2003-2004 Mechanical, Pit Crew, Grady's #2
T-Hawks 1100 2005-2007 Mechanical, Driver, Coach
Rhodewarriors 121 2007 IRI Operator
PiraTech 2023 2008 Mechanical, Coach
Gael Force 126 2009-2010 Mechanical, Photographer
Current [RIDE] Volunteer Coordinator
Unread 15-02-2004, 19:27
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
I think you have hit on the real key here. As the wheels are currently configured, they MIGHT pass inspection. But the first time they chip on the platform lip and get a sharp edge, they would then pose a damage hazard to the carpet. At that point, you run the risk of being DQ'd.
My best advise: just in case, take an extra set of un-modified wheels with you, and practise on changing them out real fast!
-dave
Unread 15-02-2004, 19:34
Hokie4Life's Avatar
Hokie4Life Hokie4Life is offline
AKA: Warren Rodgers
#0401 (Hokie Guard)
Hokie4Life is an unknown quantity at this point
Cool looking! I like the trippy colored marbles, althoug I dont think i'd like them as much if one of them punctured our robots tires after one of your maches...
Unread 15-02-2004, 19:35
It's a Bird
AKA: BoogyShoes
Re: Magic wheels
The rule is prevent field damage, not just carpet damage. It specifically states in the rule, "carpet or other playing surfaces".
Unread 15-02-2004, 19:42
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
I think that the level of contreversy this is causing on CD alone is reason enough to check with FIRST to make sure you'll be ok.
Looks cool though. Hope it passes.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 15-02-2004, 19:50
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
-dave
Really good looking wheels but the first thing that came to my mind after reading your method of fabrication is "flying marbles".
Under extreme conditions when the the rubber heats up and the wheels are spinning very fast. I would be afraid that the marbles will come out and go flying.
Something to consider-
From a previous robot inspector
popularis de ob instinctus agnitionis scientia technologia
Home website: www.nycnjfirst.org
Member of NEMO & e^(i*pi)+1 Fraternity.
Member of Friends of Robots
Member of NYCFIRST Planning Committee
Unread 15-02-2004, 21:24
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
yeah i would think you would want to hold them in with something if not epoxy then silicon rubber or even hot glue! and consider replacing the marbles with say teflon bals... glass is nasty when it shatters
"You're not a real programmer until all your sentences end with semicolons;"
Unread 15-02-2004, 21:33
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
If that frame around the wheel prevents the wheel from contacting the diamond plate, you should be in better shape. So if that frame is below 6" tall, I think you might be ok. It is still a hard call. And it you were planning on climbing the stairs, you could use the other two wheels (probably climb better than marbled-wheels anyway).
Edit - The frame would have to be really low, because of the smaller steps.
See you in DC!
pic: Team 66: New wheels CD47-Bot Extra Discussion 7 06-02-2004 22:47
pic: Team 67's Wheels CD47-Bot Extra Discussion 10 29-01-2004 14:09
pic: 222's wheels CD47-Bot Robot Showcase 14 11-12-2003 08:14
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
