Go to Post In my opinion, I wouldnt want gifts or praise from people about my help to a robotics team, all I would want is a thank you, that would make all my hard work and efforts worth while and it would prove to me that I could actually be making a difference in the students lives - Mike Schroeder [more]
Unread 15-02-2004, 22:54
Re: Distro block, maxi fuse box, and ground stem
Hello All,
The wiring diagram (schematic) shows the wiring for this year. If you use 40 amp circuit breakers you must use the distro block and the 4 way maxi block or allowed equivalent. One of the Q&A responses allow you to remove the unused section of both the distro block and the maxi fuse block. All teams must use the ground stud. If you use the maxi fuse block, the grounds for those motors must come back to the distro block just as shown in the diagram and return to the stud via #6..
