Go to Post But sometimes you just wanna build something that's MFD. - Andrew Schreiber [more]
Unread 15-02-2004, 22:31
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
Two pressures?
Is it possible to use different pressures for the extend and retract on the pistons? For example, use 60 psi for the retract and regulate the 60 psi down to 30 psi for the extend?
Suddenly being rejected from college feels right during the build season. Now I am a mentor.
Unread 15-02-2004, 22:35
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Two pressures?
why would you want more pressure on the retract then the extend. In pneumatics like we have there is no real "speed control" or "stroke distance control" that we have by limiting pressure input on different sides.
-Michael Dessingue
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
Re: Two pressures?
you could use the 2ndary regulator on one of the pneumatic lines downstream from the solenoid valve.
NOTE: im not entirly sure how this would work thoug, i dont know how air reacts passing backwards through the reg. I am under the impression it gets vented, but it might restrict flow then. try it!
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 15-02-2004, 22:40
Re: Two pressures?
in te kit of parts *not sure what they are called* there are little pressure regulators that attach to either end of the piston. The are whit and orange and have a little turny knob on the top for adjusdments. Put those on and tweak around with that.
Unread 15-02-2004, 22:42
Re: Two pressures?
please spell check all posts before posting
-Michael Dessingue
ngreen ngreen is online now
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: Two pressures?
THe second regulator would be your best choice. It should work but just test it.
Unread 15-02-2004, 22:43
NoRemorse's Avatar
AKA: Brian Roberts
Re: Two pressures?
those are not pressure regulators, those things are called "Flow Controls". They allow the flow of the air passing OUT of the piston to be controlled. They can be used as 1 way valves to, because air in is unefected, and air out can be cut off when the valvr is all the way closed.
Unread 15-02-2004, 22:49
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Re: Two pressures?
Well, you're 1/2 right. True, you can not regulate stroke distance with pressure. You CAN regulate the speed at which the piston moves (and it can be different extending and retracting) with the small fittings that have the white knobs.
You also CAN create a very simple multi-positioning setup with parts from the kit. This will allow you to extend a piston part of the way and stop.
You typically do this by using 2 selenoids. One double, and one Single.
We did this last year, I can't entirely remember the setup.
But It's not difficult, or space consuming or anything
The spell check feature has not been readded into the forums yet.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 15-02-2004, 22:50
Re: Two pressures?
ahh oh well im not too worried about my spelling... i know i can type right but im usually just to lazy to go back and fix my lazy online talk
Unread 15-02-2004, 22:55
Re: Two pressures?
Well I was trying to think of a way to limit the amount of air we lose when you lift ourselves onto the bar. We would still need the 60 psi (actually would it be better to have the retract only exert 130 lbs of force??) to lift, but do we really need 75 cu In at 60 psi to be lost just to extend the piston?
Unread 15-02-2004, 22:58
jimfortytwo jimfortytwo is offline
AKA: Jim Paulos
#0418 (Purple Haze)
Team Role: Student
jimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nice
Send a message via ICQ to jimfortytwo Send a message via AIM to jimfortytwo Send a message via Yahoo to jimfortytwo
Re: Two pressures?
EDIT: So my guess at your intent was wrong. And four other people replied while I was typing this. However, maybe this post with have intrinsic value to someone else. Consider it a recap.
I'm going to sort of ignore your question, because I've got a feeling you're asking how to dodge the 10ft/sec rule with a piston bar hanger. I assume that what you're trying to do is actually control piston extension and retraction *speed*. If thats the case, using a regulator to restrict pressure for the extension is only indirectly going to solve your problem. NoRemorse's flow controls screw directly onto the pistons, and will allow you to adjust stroke speed without effecting force.
If you really want to restrict *pressure* for whatever reason, and you fully realize that this will have only indirect impact on piston speed, you'll need that second full blown regulator.
Unread 15-02-2004, 23:01
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Two pressures?
As an answer to the original question, if a secondary regulator downstream of the double solenoid doesn't work because of the directionality of the regulator, you could always use two single solenoids and have one supplied by the secondary regulator.
Also note: I recall accidentally hooking a regulator up backwards once, and it completely failed to regulate pressure, so I think the regulator after the double solenoid should work. If you want to have more than one cylinder set up like this, single solenoids would be the way to go since I think you're limited to just the regulators in the kit.
Also, to everyone else, I can think of one good reason to set up a cylinder like this. If you know for certain that you don't need 60psi on the retract and only need 30psi, setting the system up like this could potentially save you a lot of stored air and battery power, depending on how often you cycle the cylinder. It works out to about a 25% savings for every extend-retract cycle. That could potentially be very important.
Edit:
I'm a slow typist, but I swear I thought of that before he posted his intentions. Honest.
Unread 15-02-2004, 23:02
Re: Two pressures?
Not exactly trying to dodge the 10 ft/sec rule. It was more of a way to reduce the amount of air we exhaust when we extend the piston so we don't need to wait 30 seconds for the system to gain enough pressure to fully retract the piston.
Unread 15-02-2004, 23:04
Re: Two pressures?
Edit:
Ahh much thanks.. We are all forum hawks tonight.
NoRemorse's Avatar
AKA: Brian Roberts
Re: Two pressures?
Well, this is the info I can give you.
1) The piston has the most force when extended (you probably knew this though)
2) In this situation I don't know what you are trying to do makes sence. Are you regulating down the pressure it uses one way to below 60, or do you want it to be more on one side. I believe that you may only use 60psi on the cylenders.
3)If you want one side at 60psi, and the other at a lower, you may need 2 seperate solenoids to accomplish this.......
[tanks]=====['T']===[reg at 60psi]===[solenoid]===[r]
.....................\====[reg at 30psi]===[solenoid]===[e]
DISREGAURD the dots!
r and e are 'extened' and 'retract'
I don't know if ths what your shooting for though
