#9
Re: Interrupts per second
True, except you are dealing with two layers of interupts here. The high priority interupt can interupt your low priority interupt. And since we don't know exactly what IFI is doing with their code...
I'm learning a LOT about what doesn't work with this machine. |
| INT2 and INT3 interrupts not working | Mercutio | Programming | 4 | 01-02-2004 13:27 |
| EDU Demo Code: Encoder Interfacing Using Interrupts | Kevin Watson | Programming | 4 | 08-01-2004 23:14 |
| Interrupts Questions | mightywombat | Programming | 0 | 03-01-2004 14:50 |
| Problem with interrupts on the PIC | Mike Betts | Programming | 7 | 16-12-2003 21:26 |
| Interrupts on the EDU-RC? | Andrew | Programming | 3 | 13-11-2003 23:16 |
