Go to Post Robotics is better than Football. Robotics > Football !!! - Arkorobotics [more]
Unread 12-02-2004, 11:53
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Interrupts per second
Anyone know how many interrputs per second the RC can handle? The Microchip docs don't seem to say and I did a search but could not locate any information on the forum. Thanks for any information.
Steven
Unread 12-02-2004, 12:26
Re: Interrupts per second
Steven
Check this thread http://www.chiefdelphi.com/forums/showthread.php?t=24463
Unread 12-02-2004, 12:43
Thanks, don't know why my searches missed that...
Unread 12-02-2004, 12:47
I actually searched for the number "5000".
It can be pretty hard to search for things on these forums unless you can remember a unique word or value from a thread, since the same terms get used over and over even if they aren't directly related to the thread topic.
I have trouble finding my own posts where I've previously posted an answer or code!
Unread 12-02-2004, 19:37
Yeah, when I searched for interrupts per second, it eliminated per second entirely and searched for just interrupts... did me a whole lot of good
Unread 13-02-2004, 13:48
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
Actually, it depends entirely on how long it takes to execute your Interupt Handler code. If you keep triggering interupts before the last one finished, you end up interupting the interupt. Do this too many times and you blow the stack and the thing crashes.
So, the REAL question is: How much time has IFI given us to service an interupt without blowing up their code?
Chow for now,
Steve
Unread 13-02-2004, 18:59
I figured that, since the interrupt simply calls a function which increments a variable, I shouldn't have any trouble with that...
Unread 13-02-2004, 20:12
Most processors block further interrupts on a pin once the first one has been received
so unless you re-enable interrupts inside the interrupt routine, it will not be able to interrupt the interrupts - usually you enable them in the last instruction before you return, or in some processors, the return-from-interupt instruction itself re-enables them
Unread 16-02-2004, 00:34
emusteve's Avatar
AKA: Steve Martin
#0470 (Alpha Omega)
True, except you are dealing with two layers of interupts here. The high priority interupt can interupt your low priority interupt. And since we don't know exactly what IFI is doing with their code...
I'm learning a LOT about what doesn't work with this machine.
Unread 16-02-2004, 14:42
I think RETFIE does this; I seem to remember reading it in the docs...
Unread 17-02-2004, 13:59
Jeff McCune's Avatar
Jeff McCune Jeff McCune is offline
Alpha Geek
#0677 (The Wirestrippers)
Jeff McCune is on a distinguished road
Send a message via ICQ to Jeff McCune Send a message via AIM to Jeff McCune
Chow for now,
Steve
Interrupts are disabled while executing an interrupt handler. This is why it's important to keep interrupt routines small, so you don't miss events.
Team 677 - The Wirestrippers - Columbus School for Girls and The Ohio State University
EMAIL: mccune@ling.ohio-state.edu
...And all you touch and all you see
Is all your life will ever be...
INT2 and INT3 interrupts not working Mercutio Programming 4 01-02-2004 13:27
EDU Demo Code: Encoder Interfacing Using Interrupts Kevin Watson Programming 4 08-01-2004 23:14
Interrupts Questions mightywombat Programming 0 03-01-2004 14:50
Problem with interrupts on the PIC Mike Betts Programming 7 16-12-2003 21:26
Interrupts on the EDU-RC? Andrew Programming 3 13-11-2003 23:16
