Go to Post They just kind of sit there chilling, like "Hey I'm a trailer, where's my robot?" - artdutra04 [more]
Unread 08-02-2004, 14:31
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
Pressure Switch
How are we suppose to wire the cable for the pressure switch to make the compressor turn off. Do we use PWM cables and if so what is the pinout. I am also unsure of how to code the pressure switch in the new controller. Please post your ideas. Thanks
Matthew
Unread 08-02-2004, 15:28
Re: Pressure Switch
you need to get the FRC (full size robot controller) user manual from the innovationfirst web site - it shows the pinouts for the digital inputs
and if you look at the default code I believe there is already a digital input pin setup and a relay output that will run when the pressure is low, and shut off when its high
use the grey wire that came in the kit, the thin one - I forget if it has two or three wires in it - and cable it to the signal and gnd pins of the digital input on the RC. The on/off sensor is the one with the two screws - and it doenst need power - its an on/off switch inside.
Unread 15-02-2004, 22:29
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: Pressure Switch
The default code already has INPUT 18 assigned to the pressure switch, and RELAY 8 assigned to a SPIKE relay per say that would be wired to the compressor.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 16-02-2004, 01:06
Roland's Avatar
Roland Roland is offline
Post-A-Holic
#1466
Team Role: Webmaster
Roland is infamous around these partsRoland is infamous around these partsRoland is infamous around these parts
Re: Pressure Switch Wiring Question
We chopped up a PWM cable and wired it to the gray cable that was in the kit. Works fine.
Unread 16-02-2004, 01:25
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
I'm not sure if it's the same as last year, but the judges made up re-wire out pressure switch to the digital outputs before we could participate.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
pressure switch Antonio Pneumatics 10 31-01-2003 03:52
pressure switch piconysm Technical Discussion 5 14-02-2002 23:15
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
