Go to Post I need to start sleeping now to make up for build season - Kingofl337 [more]
Unread 16-02-2004, 01:08
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 254 Drivetrain
Unread 16-02-2004, 01:11
Jessica Boucher Jessica Boucher is offline
FIRST Historian
Jessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond repute
Re: pic: 254 Drivetrain
Soooo many people using that tread material for their whatever. Not being on a team, I have yet to see this stuff up close. Can you give me a rundown on why this stuff is good?
jessicaboucher.com
FRC Alum, Mentor, Volunteer, lots of things.
Championship Volunteer of the Year, 2016
Advisor, NE FIRST
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
is that 8 double selenoids i'm counting?
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 16-02-2004, 01:12
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Question: What has 6 wheels and goes really fast??
Answer:What is another regional winner - and maybe more????????
Nice looking bot this year guys. I was finally able to watch the Science Channel Documentary on FIRST featuring your team and I was impressed with your team's showing in CA!!
Maybe this year is your year???
LOL, but that's what we all want though, right?? To win the Championships??
See you down in Atlanta hopefully!!
BTW, what's your weight in this picture??? It seems like it's awful close to 130lbs... lol
I see lots o' goodies!!
Unread 16-02-2004, 02:10
phrozen solyd's Avatar
phrozen solyd phrozen solyd is offline
AKA: Adrian Santos
#0254 (Cheesy Poofs)
phrozen solyd is just really nicephrozen solyd is just really nicephrozen solyd is just really nicephrozen solyd is just really nicephrozen solyd is just really nice
Send a message via AIM to phrozen solyd
Whew, ok, lots of questions to answer:
Jessica - We've been using the waffle tread material since 2002, and it's worked out great. The stuff's pretty easy to find (it's actually conveyor belt material you can order from McMaster), and it provides good traction on almost any surface.
pras - There are only 2 double solenoids. The other 6 are singles.
Elgin - Haha, thanks for the props. We weighed the complete robot last night, and it was exactly 129 pounds...it doesn't leave too much weight for powdercoating, which we think will add about 2 pounds. Looks like we might have to resort to desperate measures like cutting off a couple cm off each bolt or cheese-holing everything
Unread 16-02-2004, 02:13
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
If you're using 8 solenoids, I'm guessing you're gonna be going for multi-positioning with the pneumatics this year?
Unread 16-02-2004, 05:36
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
yea lets hear a little more about the beafy pnumatics this year you guys are using along with 60? Also i am curious about your drive train!
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
Unread 16-02-2004, 19:43
AKA: Adrian Santos
Our drive train is powered by 2 Atwoods and 2 drill motors, with 2 speeds, pneumatically shifted. The gearbox is a modification of 60's design from 2001. The 6-wheeled base is modeled after Team 25's awesomely fast and agile machine from 2003, with the center wheel on each side lower than the others by 1/8 inch, so that the robot rocks back and forth. This shrinks our wheelbase to about 13", allowing us to turn quickly.
The numerous solenoids on our bot are actually used for many different functions. One is for the cylinders that shift our gears, two are for our ball corralling "flaps", one extends our bar-grabbing hook, one actuates our gripping hook for latching onto the mobile goals, one extend the "whips" that knock off the 10-pt balls, one double solenoid actuates the claw for manipulating the large balls, and the other double solenoid engages and disengages the winch for pulling ourselves onto the bar.
Unread 16-02-2004, 19:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
It must have been a fairly major modification as the drills were different then and we didn't even have Chias.
Unread 16-02-2004, 19:57
NateBot16 NateBot16 is offline
#0528 (Dark Knights)
NateBot16 is on a distinguished road
Send a message via AIM to NateBot16
Looks great. Everything looks super organized, even down to the different color pneumatic tubes. Good luck this year.
Unread 07-04-2004, 23:51
AKA: Dr. Brooks
no team (WRRF)
How do you fasten the tread material to the aluminum so it doen't peel off?
Unread 08-04-2004, 00:23
I got to see 60's robot REALLY up close (like I stuck my head in it) at Phoenix and it is amazing how everything is packed in there. They even have this little leadscrew mechanism on their PTO winch that winds the cable evenly so it doesn't wind on top of itself. Anyway, on 60's it appeared that the 4 corner wheel's are toe'd in a bit. I was wondering what is the effect of/ reasoning for this and how does it affect the chain/sprocket alignment? Thanks.
Unread 08-04-2004, 00:57
activemx's Avatar
A M X
AKA: Akshay Dodeja
Yea thats why they have the 6 wheel caster driver just like 25 last year. They have an offset for the center wheels a little lower then the front and back wheels. so the front and back are pretty much like a powered caster. It tips over on to either front or back generally depending on the direction its driving in. This allows them to have a great turning radius.
2000-2004 MVRT 115
Unread 08-04-2004, 01:05
Yes, I know all about the 6 wheel drive and the center one being a little lower. It is just like a Home Depot shopping cart. What I was asking though is if the 4 outer wheels have toe in. On Kingman's bot, it did appear to have about 2 degrees of toe in per wheel (or "toe out" depending on your perspective of front and rear of the vehicle)
Unread 08-04-2004, 01:49
AKA: Adrian Santos
The treads are held into the wheels with screws.
- Adrian Santos
Team 254, the Cheesy Poofs
pic: team 254 teaser CD47-Bot Robot Showcase 10 02-03-2004 10:06
pic: team 254 teaser CD47-Bot Robot Showcase 4 07-02-2004 09:37
pic: Team #461 Drivetrain CD47-Bot Robot Showcase 8 05-03-2003 08:07
pic: Team 254 Robot Cart (1 of 3) CD47-Bot Extra Discussion 3 28-02-2003 16:51
254 The Best Partner in FIRST sfield Regional Competitions 5 03-04-2002 23:23
