Go to Post However, do not confuse faith in your ability to overcome challenging obstacles, with the difficulty of the obstacles themselves. - Joe G. [more]
Unread 15-02-2004, 22:17
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Question New LED Lights this Year, spec for placement?
Does anyone know if First released a spec for the new light placement on the robots this year?
In the past there was only one light, we wondered if there was documentation on the placement of the lights. Like one per side since there are four lights or anything like that too read. We can't find any documentation that would point this out if this has been defined or not. Any pointers would be grateful.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 15-02-2004, 22:20
Re: New LED Lights this Year, spec for placement?
[quote]<R08> Robots must use all four Team Color LEDs provided in the kit to display their alliance color (red or blue).
Previous years rotating lights are not allowed. All four Team Color LEDs must be mounted on the robot
such that their displayed color is visible over the entire 360 degree circle around the robot from a distance
of at least 100 feet. Instructions for connecting the lights are provided in the Innovation First controller
manual. The Robot Controller directly powers and controls the Team Color LEDs. The user has no
control over the Team Color LEDs and no programming is required[quote]
Unread 15-02-2004, 22:21
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
Rule <R07> Robots must display their team number, sponsor and school names, and/or logos. The judges, referees,
and announcers must be able to easily identify robots by Team Number. Teams must display their Team Number in four locations at approximately 90-degree intervals around the side of the robot. The numerals must be at least 4 inches high, at least in 3/4 inch stroke width and in a contrasting color from its background. Team Numbers must be clearly visible from a distance of not less than 100 feet.
Matthew
Unread 15-02-2004, 22:22
Elgin Clock's Avatar
FRC #0237 (Black Magic)
**not a real answer**
I think I saw somewhere that said you had to mount them in 90 degree's apart from each other... (if their are 4?)
So, on all 4 side of your robot, like the team number.
(I think)
Unread 15-02-2004, 22:34
Controls Engineer
AKA: chakorules
Sweet...thanks guys. That was a FAST reply!
Favorite CD quote:
Unread 15-02-2004, 22:38
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer &amp; Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
To put them on your robot you don't need alot of space and its 0% effort to mount. Most robots if not all will be in a 4 sided shape (square / rectangle) all you need to do is put 1 led on each side of the robot and high enough so that its visible but well proctected from any significant damage !
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 16-02-2004, 02:28
Geoff Geoff is offline
h4x0r sup3r10r
#0246 (Overclocked)
Geoff is an unknown quantity at this point
Send a message via ICQ to Geoff Send a message via AIM to Geoff
use road flares, not LEDs
Unread 16-02-2004, 02:34
TOLEDO TOLEDO is offline
Junior Member
TOLEDO has a little shameless behaviour in the past
Please...the chemicals would create some dangerous reactions.
Use magnesium.
Unread 16-02-2004, 02:46
telkanuru's Avatar
telkanuru telkanuru is offline
Generic Carbon Unit
#0246 (Overclocked)
telkanuru is an unknown quantity at this point
Send a message via AIM to telkanuru
Thermite adds an interesting chemichal component that will amuse your ChemEng people to no end (and the officials, as it burns through your robot, the carpet, the field supports, the concrete floor, and the bedrock beneith.
"He who has cares also has brandy."
-Gothe
Murphey was an optimist.
Unread 16-02-2004, 05:20
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
this is somewhat off topic
but how exactly are teams mounting the lights?
I glanced at them tonight, and i didn't see any easy way to attach them?
should we just epoxy them or did i miss some kind of mounting hole?
Unread 16-02-2004, 09:40
ReggieB ReggieB is offline
President
AKA: Aaron
#0449 (Blair Robot Project)
ReggieB is on a distinguished road
Send a message via AIM to ReggieB
Also on mounting- Can we cover up a corner (or two) of the led's for mounting?
Unread 16-02-2004, 13:43
mtaman02's Avatar
if im not mistaken i think there was a screw hole in them. where you can mount them like a picture frame. if you epoxy them and FIRST wants you to move them else where well you get the idea! all you need is a small hole if there isn't already one there and put a small screw to hole it up.
quote/ ReggieB also on mounting- Can we cover up a corner (or two) of the led's for mounting?
covering a corner or two ??? don't know what your talking about (the edges or the front of the face plate?) if its the front you may need an official ruling if its the side of the led then i don't see why not!
Volunteer Resume:
Unread 16-02-2004, 17:32
BillyGoats BillyGoats is offline
Paper Eater
None #0061 (Intimidators)
BillyGoats can only hope to improve
Send a message via AIM to BillyGoats
Well we used a little L bracket and some velcro. Well can not find a picture of it on our website ill tell them to upload it 2morrow or something. The URL is
http://www.valleytech.k12.ma.us/robo...photos2004.htm
Should be up some time tuesday(17th) night.
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
Problems with this year... and a solution? archiver 2001 2 24-06-2002 03:23
Wow! what a year archiver 2000 8 23-06-2002 22:43
why why why...? archiver 2001 34 23-06-2002 22:13
Making heads or tails of the new announcement... Jessica Boucher General Forum 66 26-09-2001 11:13
