Go to Post There are few things I hate more in life than electrical tape residue. - AdamHeard [more]
Unread 16-02-2004, 11:22
1166's Avatar
1166 1166 is offline
AKA: Vex
#1166 (The Highlanders)
Team Role: Animator
1166 can only hope to improve
Send a message via AIM to 1166
Exclamation Please help asap
Where do the victor motor 3 pin wires plug into exactly? The victor motor is hooked up to the van door motor.
-Vex
Unread 16-02-2004, 11:29
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: Please help asap
One side of the cable plugs into the PWM input on the Victor, and the other goes to the PWM Outputs on the RC. Make sure that you plug into both correctly. The victor has the letters W,B,R to represent the color of the wire. The RC also clearly labels which colors go where.
When it comes to connecting the PWM cable, it doesn't matter which type of motor is connected. You will choose which RC output based on your software.
As a side note, the Spikes would plug into the Relay outputs of the RC.
Unread 16-02-2004, 11:30
1166's Avatar
AKA: Vex
Team Role: Animator
Where do they plug into exactly on the robot controller?
Unread 16-02-2004, 11:35
Re: Please help asap.. Where do the victor motor 3 pin wires plug into
They connect to the pins that say "PWM Outputs"
They are at the top of this picture
http://www.innovationfirst.com/FIRST...Controller.gif
Unread 16-02-2004, 11:36
1166's Avatar
AKA: Vex
Team Role: Animator
Which number?
Unread 16-02-2004, 11:37
I'll contact you via PM
Unread 16-02-2004, 11:51
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
I hate to sound mean, but you should really read the IFI docs. Everything you're asking about is explained VERY clearly in the information provided by IFI - you'll be better prepared to work with the control system if you have a fair amount of familiarity with it, and spending 20 minutes flipping through the manual is a good way to gain that familiarity.
Unread 16-02-2004, 11:52
1166's Avatar
AKA: Vex
Team Role: Animator
we have not the time
merci anyway
Unread 16-02-2004, 12:01
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
Plug the one end into the Victor with the black wire closest to the fan.
Plug the other end into a set of 3pins on the Robot controller that is labeled PWM Outputs.
The number of the PWM (1-16) is the number you need to use in the code to control that particular speed controller.
ie.
We have a Victor for the left drive that is conected to PWM16
The right Drive motor connected to PWM15.
In Our code we say
 pwm15 = 254;
 pwm16 = 0;    // reversed due to motors pointing opposite.
and our robot will go forward at full speed.
If we plugged the motors into pwm1 and pwm2, and used the above code, the robot would not be sending the signals to the right jacks.
Hope this helps.
Remember frustration will just frustrate you farther and nothing will get accomplished.
Reading the documentation is always a good idea and will assist in clarifying what you are trying to do.
Phil
Unread 16-02-2004, 12:04
1166's Avatar
AKA: Vex
Team Role: Animator
ie.
In Our code we say
 pwm15 = 254;
Hope this helps.
Phil
Merci mon ami
Unread 16-02-2004, 12:07
Phil_Lutz's Avatar
Phil Lutz
#0851 (Froggers)
Originally Posted by 1166
Merci mon ami
bienvenue
Ir Sensor Needed Asap! Ryan Albright Electrical 10 14-02-2004 13:06
Very BIG bug...Brandon, please fix this one ASAP! IMDWalrus CD Forum Support 1 11-02-2004 22:42
Q&A Discuss: FESTO Help ASAP!!!! CD47-Bot Extra Discussion 3 16-02-2003 10:55
Course Curriculum for A First Class, Please Respond ASAP archiver 2001 0 24-06-2002 01:33
survey for the guys..but i need results ASAP A. Leese Chit-Chat 4 05-06-2002 16:50
