Go to Post I'd say it is somewhat addicting. But I think that is a good thing. It proves that knowledge can be addicting. How cool is that? Now, if we could just get everyone addicted to knowledge, just think of what we can accomplish.:D - Molten [more]
Unread 16-02-2004, 12:01
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
Re: Please help asap.. Where do the victor motor 3 pin wires plug into
Plug the one end into the Victor with the black wire closest to the fan.
Plug the other end into a set of 3pins on the Robot controller that is labeled PWM Outputs.
The number of the PWM (1-16) is the number you need to use in the code to control that particular speed controller.
ie.
We have a Victor for the left drive that is conected to PWM16
The right Drive motor connected to PWM15.
In Our code we say
 pwm15 = 254;
 pwm16 = 0;    // reversed due to motors pointing opposite.
and our robot will go forward at full speed.
If we plugged the motors into pwm1 and pwm2, and used the above code, the robot would not be sending the signals to the right jacks.
Hope this helps.
Remember frustration will just frustrate you farther and nothing will get accomplished.
Reading the documentation is always a good idea and will assist in clarifying what you are trying to do.
Phil
Ir Sensor Needed Asap! Ryan Albright Electrical 10 14-02-2004 13:06
Very BIG bug...Brandon, please fix this one ASAP! IMDWalrus CD Forum Support 1 11-02-2004 22:42
Q&A Discuss: FESTO Help ASAP!!!! CD47-Bot Extra Discussion 3 16-02-2003 10:55
Course Curriculum for A First Class, Please Respond ASAP archiver 2001 0 24-06-2002 01:33
survey for the guys..but i need results ASAP A. Leese Chit-Chat 4 05-06-2002 16:50
