Go to Post *wonders if omni wheel rollers come in MOE green or have to be dyed* - EricH [more]
Unread 16-02-2004, 13:23
Catastrophy Catastrophy is offline
AKA: Vince
#0704
Catastrophy is an unknown quantity at this point
Send a message via AIM to Catastrophy Send a message via MSN to Catastrophy
Odd counter problems
Ok well, I'm trying to run through a loop where it does
armcounter++;
Armcounter is defined at the top of user_routines_fast.c. I try a print_f to print out armcounter but it gives [null] on the ifi_loader. My motors just keep running for ever because it doesn't ever have armcount equal to the number I supply. Any clues?????
Unread 16-02-2004, 13:25
Re: Odd counter problems
you need to declare armcounter as a static int. Otherwise, it gets created and destroyed on the stack each time you enter and leave the function.
Unread 16-02-2004, 13:28
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
armcounter++;
You'd have to show me how you have the printf setup, but you probably got it wrong. This should be similar to what your printf should be:
printf("\nArm counter: %i\n", (int)armcounter);
Unread 16-02-2004, 13:29
Programming User
He says at the top of user_routines_fast.c. I assume that means he made it a global.
PS What type is armcounter?
Unread 16-02-2004, 13:56
AKA: Vince
#0704
its a short.
Unread 16-02-2004, 14:02
Programming User
its a short.
Try the printf I showed earlier. It should work. Just copy and paste it over your old one.
Unread 16-02-2004, 14:28
AKA: Vince
#0704
ok I did and now theres nothing there, its not printing anything.
Unread 16-02-2004, 14:33
Programming User
Hum, well, try just using the following line. It's guarranteed to print and if it doesn't, it means that it is never getting called and you'll have to look at your code.
printf("Test");
--EDIT--
If it doesn't work then post your code and people can look at it.
Unread 16-02-2004, 14:44
AKA: Vince
#0704
It printed test but here it is. I'm using a basic auto right now so i can debug everything first.
Unread 16-02-2004, 14:54
Programming User
What exactly is the output say? Does the 'arm value of armcounter' print anything? What does it print?
--EDIT--
Try changing the %i in the printf to %d.
Unread 16-02-2004, 14:57
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
A few things I saw after glancing at it:
if (armcounter = 15) //will raise arm.
   pwm06=0;
else
   armcounter++;
   pwm06=255;
sould be
if (armcounter == 15) //will raise arm.
   pwm06=0;
else {
   armcounter++;
   pwm06=255;
It is VERY rare that you'll actually want to use a single = in an if, so watch out for that, and also be careful with your curly braces.
That said, I believe the code in its original form should have printf'd 15 over and over and over. Was it doing that, or just not printing anything?
Unread 16-02-2004, 15:03
Programming User
   pwm06=0;
else
   armcounter++;
   pwm06=255;
sould be
   pwm06=0;
else {
   armcounter++;
   pwm06=255;
Missing a = is an easy thing to do. It's one of those powerful, useful things that C/C++ lets you do, but isn't what you want most of the time.
Unread 16-02-2004, 15:08
AKA: Vince
#0704
Well the = was something i accidently did when moving it i had it in the code i was using. and btw its just not printing anything.
Unread 16-02-2004, 15:09
Programming User
So, the "test" prints, but the other thing doesn't?
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
printf("Test");
--EDIT--
Try
printf("Test\n");
instead. If it works anything like printf on any other system, it won't flush the buffer until it gets a newline...
Meeting FIRST People in odd places Jeff Waegelin General Forum 219 04-03-2012 13:10
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Joystick problems archiver 2001 3 24-06-2002 02:40
A couple of problems I observed at the MAR archiver 2000 3 23-06-2002 22:27
Radio problems -- not archiver 2000 1 23-06-2002 22:23
