Re: Odd counter problems
ok I did and now theres nothing there, its not printing anything.
printf("Test");
--EDIT-- If it doesn't work then post your code and people can look at it. |
It printed test but here it is. I'm using a basic auto right now so i can debug everything first.
--EDIT-- Try changing the %i in the printf to %d. |
Catastrophy, is your problem fixed now that it is counting, or do you have more problems? |
well the motors still arnt stopping.
#8
If you are using the corrections that Rob posted, pwm06 will go forward for about 1/3 a second and then go in reverse forever. You also have a similar behavior for pwm07 (assuming you corrected the errors) |
#9
A few things I saw after glancing at it:
if (armcounter = 15) //will raise arm. pwm06=0; else armcounter++; pwm06=255; Code:
if (armcounter == 15) //will raise arm.
pwm06=0;
else {
armcounter++;
pwm06=255;
That said, I believe the code in its original form should have printf'd 15 over and over and over. Was it doing that, or just not printing anything? |
#10
Well the = was something i accidently did when moving it i had it in the code i was using. and btw its just not printing anything.
#12
pwm06=0;
else {
armcounter++;
pwm06=255;
you said that the "motors weren't stopping" - of course they aren't: 0 is full reverse, 255 is full forward. if you want a motor to stop, set the PWM to 127. |
#14
Well i got it working i was messign with the code when i posted it so i accidently left stuff out. Thanks Tex helped a lot.
#15
printf("Test\n");
| Meeting FIRST People in odd places | Jeff Waegelin | General Forum | 219 | 04-03-2012 13:10 |
| Do you all have problems with.... | Munkaboo | Website Design/Showcase | 19 | 03-03-2003 19:51 |
| Joystick problems | archiver | 2001 | 3 | 24-06-2002 02:40 |
| A couple of problems I observed at the MAR | archiver | 2000 | 3 | 23-06-2002 22:27 |
| Radio problems -- not | archiver | 2000 | 1 | 23-06-2002 22:23 |
