Go to Post I can follow directions, but if it's not in the directions, I'm lost. - rclothier [more]
Unread 16-02-2004, 14:33
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Odd counter problems
Originally Posted by Catastrophy
ok I did and now theres nothing there, its not printing anything.
Hum, well, try just using the following line. It's guarranteed to print and if it doesn't, it means that it is never getting called and you'll have to look at your code.
printf("Test");
--EDIT--
If it doesn't work then post your code and people can look at it.
Unread 16-02-2004, 14:44
Catastrophy Catastrophy is offline
AKA: Vince
#0704
Catastrophy is an unknown quantity at this point
Send a message via AIM to Catastrophy Send a message via MSN to Catastrophy
It printed test but here it is. I'm using a basic auto right now so i can debug everything first.
Unread 16-02-2004, 14:54
Programming User
What exactly is the output say? Does the 'arm value of armcounter' print anything? What does it print?
--EDIT--
Try changing the %i in the printf to %d.
Unread 16-02-2004, 15:50
Remeber that IFI implemented printf and that it isn't a "standard" implementation. Only the %s, %lx, %d, %x, %u, %X directives are parsed.
Catastrophy, is your problem fixed now that it is counting, or do you have more problems?
Unread 16-02-2004, 15:58
Programming User
Oh, didn't know those limitations. Thanks
Unread 16-02-2004, 16:14
AKA: Vince
#0704
well the motors still arnt stopping.
Unread 16-02-2004, 16:40
Please post the code that you are using currently.
If you are using the corrections that Rob posted, pwm06 will go forward for about 1/3 a second and then go in reverse forever. You also have a similar behavior for pwm07 (assuming you corrected the errors)
Unread 16-02-2004, 14:57
Happy Birthday! rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
A few things I saw after glancing at it:
if (armcounter = 15) //will raise arm.
   pwm06=0;
else
   armcounter++;
   pwm06=255;
sould be
if (armcounter == 15) //will raise arm.
   pwm06=0;
else {
   armcounter++;
   pwm06=255;
It is VERY rare that you'll actually want to use a single = in an if, so watch out for that, and also be careful with your curly braces.
That said, I believe the code in its original form should have printf'd 15 over and over and over. Was it doing that, or just not printing anything?
Unread 16-02-2004, 15:03
Programming User
   pwm06=0;
else
   armcounter++;
   pwm06=255;
sould be
   pwm06=0;
else {
   armcounter++;
   pwm06=255;
Missing a = is an easy thing to do. It's one of those powerful, useful things that C/C++ lets you do, but isn't what you want most of the time.
Unread 16-02-2004, 15:08
AKA: Vince
#0704
Well the = was something i accidently did when moving it i had it in the code i was using. and btw its just not printing anything.
Unread 16-02-2004, 15:09
Programming User
So, the "test" prints, but the other thing doesn't?
Unread 16-02-2004, 17:10
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
   pwm06=0;
else
   armcounter++;
   pwm06=255;
sould be
   pwm06=0;
else {
   armcounter++;
   pwm06=255;
remember that you need to add the curly braces, not just change the equals sign to a double-equals. w/o the braces, the code is equivalent to this:
   pwm06=0;
else {
   armcounter++;
pwm06=255;
note how pwm06 will always end up as 255, no matter what the value is.
you said that the "motors weren't stopping" - of course they aren't: 0 is full reverse, 255 is full forward. if you want a motor to stop, set the PWM to 127.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 16-02-2004, 23:41
AKA: Vince
#0704
Well i got it working i was messign with the code when i posted it so i accidently left stuff out. Thanks Tex helped a lot.
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
printf("Test");
--EDIT--
Try
printf("Test\n");
instead. If it works anything like printf on any other system, it won't flush the buffer until it gets a newline...
Unread 16-02-2004, 15:12
Programming User
Originally Posted by steven114
Try
printf("Test\n");
Yeah, that is true, but it did print for him. The wierd thing is, at least from what he has said, the line that is right below it doesn't say print anything, even though it should.
Meeting FIRST People in odd places Jeff Waegelin General Forum 219 04-03-2012 13:10
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Joystick problems archiver 2001 3 24-06-2002 02:40
A couple of problems I observed at the MAR archiver 2000 3 23-06-2002 22:27
Radio problems -- not archiver 2000 1 23-06-2002 22:23
