Go to Post FIRST has a funny way of connecting people... - Jaine Perotti [more]
Unread 16-02-2004, 15:12
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Odd counter problems
Originally Posted by steven114
Try
printf("Test\n");
instead. If it works anything like printf on any other system, it won't flush the buffer until it gets a newline...
Yeah, that is true, but it did print for him. The wierd thing is, at least from what he has said, the line that is right below it doesn't say print anything, even though it should.
Unread 16-02-2004, 15:23
Catastrophy Catastrophy is offline
AKA: Vince
#0704
Catastrophy is an unknown quantity at this point
Send a message via AIM to Catastrophy Send a message via MSN to Catastrophy
Well for the variable, it print Arm and then nothing after it.
Unread 16-02-2004, 15:24
Programming User
Could you paste the output from the code here?
Unread 16-02-2004, 15:26
Programming User
Well, I can't figure it out. It should work. Any suggestions, The Lucas?
--EDIT--
I know you're watching.
Unread 16-02-2004, 15:32
Programming User
Obviously not. Try:
printf("Arm: %d", armcounter);
--EDIT--
If that doesn't work, I don't know what to do. Sorry.
Unread 16-02-2004, 15:33
AKA: Vince
#0704
Here is a screenshot.
Unread 16-02-2004, 15:34
Programming User
I edited my last post. Take a look at it. Sorry I can't be of any more help.
--EDIT--
Someone else will come along and figure it out I'm sure.
Unread 16-02-2004, 15:38
AKA: Vince
#0704
Ok now nothing is being printed Texan from what you said to put in.
-EDIT-
its saying TestAmr, 15TestArm, 15TestArm over and over now
Unread 16-02-2004, 15:40
Programming User
I don't know what is going on. Try resetting the RC. Sorry, got to go. Hope you figure it out.
Unread 16-02-2004, 15:45
AKA: Vince
#0704
Well its counting now.
Unread 16-02-2004, 15:50
Originally Posted by Texan
Try changing the %i in the printf to %d.
Remeber that IFI implemented printf and that it isn't a "standard" implementation. Only the %s, %lx, %d, %x, %u, %X directives are parsed.
Catastrophy, is your problem fixed now that it is counting, or do you have more problems?
Unread 16-02-2004, 15:58
Programming User
Oh, didn't know those limitations. Thanks
Unread 16-02-2004, 16:14
AKA: Vince
#0704
well the motors still arnt stopping.
Unread 16-02-2004, 16:40
Please post the code that you are using currently.
If you are using the corrections that Rob posted, pwm06 will go forward for about 1/3 a second and then go in reverse forever. You also have a similar behavior for pwm07 (assuming you corrected the errors)
Unread 16-02-2004, 17:10
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Originally Posted by rbayer
A few things I saw after glancing at it:
if (armcounter = 15) //will raise arm.
   pwm06=0;
else
   armcounter++;
   pwm06=255;
sould be
if (armcounter == 15) //will raise arm.
   pwm06=0;
else {
   armcounter++;
   pwm06=255;
It is VERY rare that you'll actually want to use a single = in an if, so watch out for that, and also be careful with your curly braces.
That said, I believe the code in its original form should have printf'd 15 over and over and over. Was it doing that, or just not printing anything?
remember that you need to add the curly braces, not just change the equals sign to a double-equals. w/o the braces, the code is equivalent to this:
   pwm06=0;
else {
   armcounter++;
pwm06=255;
note how pwm06 will always end up as 255, no matter what the value is.
you said that the "motors weren't stopping" - of course they aren't: 0 is full reverse, 255 is full forward. if you want a motor to stop, set the PWM to 127.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Meeting FIRST People in odd places Jeff Waegelin General Forum 219 04-03-2012 13:10
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Joystick problems archiver 2001 3 24-06-2002 02:40
A couple of problems I observed at the MAR archiver 2000 3 23-06-2002 22:27
Radio problems -- not archiver 2000 1 23-06-2002 22:23
