Go to Post EVERYTHING in life is politics. - Amanda Morrison [more]
Unread 16-02-2004, 17:56
willross's Avatar
willross willross is offline
#1247 (System Failure)
willross has a little shameless behaviour in the past
Manual override of compressor software control
Is it acceptable for an operator to manually override the software control of the compressor on/off sequence? We would like to be able to have the software automatically turn the compressor on at some low pressure state and kick off at full pressure but we also would like to be able to use a joystick button to turn the compressor on manually rather than waiting for the pressure to drop to that low state.
Bill Ross
Autonomous to Manual control? Lint_Ninja Programming 5 16-02-2004 21:48
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
goals: how much control? Pat Sarmiento Rules/Strategy 2 18-01-2002 19:10
