Go to Post ...we might be able to take the 'out' out of 'outsourcing' - if we all share a strong cultural set of values, who exactly is 'out'? I think FIRST is a great way to do this, ... - Ian Mackenzie [more]
Unread 16-02-2004, 18:28
Jeff McCune's Avatar
Jeff McCune Jeff McCune is offline
Alpha Geek
#0677 (The Wirestrippers)
Jeff McCune is on a distinguished road
Send a message via ICQ to Jeff McCune Send a message via AIM to Jeff McCune
Pointers to structs?
I'm trying to abstract relays into a structure with a forward and reverse element. The idea is to have a single set_relay() funtion that takes a pointer to this data structure as it's input.
I can't figure out how to get mcc to accept my syntax. I've been referencing a lot of documents, so I'm pretty sure my syntax is correct, but I haven't verified it with gcc or what not. I'm going to go do that now and then post some of my example code. Was just wondering if there's problems to start with though.
Team 677 - The Wirestrippers - Columbus School for Girls and The Ohio State University
EMAIL: mccune@ling.ohio-state.edu
...And all you touch and all you see
Is all your life will ever be...
Unread 16-02-2004, 18:39
Re: Pointers to structs?
We had this discussion (well, not really a discussion, but a comment) in another thread. http://www.chiefdelphi.com/forums/sh...9&postcount=19
depending on how you are doing it, you may need to make your own macros.
Unread 17-02-2004, 13:17
Alpha Geek
After some testing in gcc, I figured it out. The more descriptive errors helped. The page I was reading was incorrect about the ordering of the type name versus the variable name. I'm actually passing a bitmask value that I #defined as a bitmask, but I just did it this way so it's easier for people to understand the pointer stuff that's going on. It's so nice having full ansi C.
struct relay_type { int fwd; int rev};
struct relay_type ball_arm_lower;
void set_relay (struct relay_type *relay, int fwd, int rev)
  relay->fwd = fwd;
  relay->rev = rev;
main()
  update_inputs ();
  set_relay (&ball_arm_lower, 1, 0);
  update_outputs ();
Laser Pointers.. archiver 2001 18 24-06-2002 00:08
