Go to Post Woody, If there is any chance your reading this ... you've changed my life. - Gope [more]
Unread 29-01-2004, 23:51
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Large Lookup Tables
I have a few look up tables I'm trying to define, and am running into problems with the C18 Linker.
The error I am getting is that the section I am loading these tables into is not big enough =/. Has anyone else used linker directives to get their large lookup tables to reside in a larger portion of memory? The table I am declaring is similar to this:
static const unsigned char mytable[256] = {
[mydata]
From what I've read so far, I need a #pragma linker directive to get this thing to go into a nice big chunk of program ROM.
Thanks in advance for the help!
-Shawn...
Unread 29-01-2004, 23:56
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Large Lookup Tables
try using the "rom" keyword in the variable definition - this allows you to place constant data in the PIC's rom, which is 32k - easily enough to store a very large lookup table or two.
i.e.
const rom unsigned char mytable[256] = {
[mydata]
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 30-01-2004, 00:27
AKA: Mr. Lim
Thanks a bundle!
Unread 31-01-2004, 01:10
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
thanks delta, I was having the exact same problem!
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 16-02-2004, 20:16
Zee Zee is offline
Zee is an unknown quantity at this point
Does this work with an EDU-bot?
Unread 16-02-2004, 21:30
Computer Guy
AKA: Dav
it should, unless for some reason they neglected to include any rom....
Who needs large Aluminum Sprockets? Joe Johnson Kit & Additional Hardware 3 30-01-2004 12:11
Picture size reduction in large quantity sanddrag Computer Graphics 8 04-06-2003 09:18
# of people on team how small or large rcubes85 General Forum 5 18-02-2003 01:35
Sensor use on Papst Large Fan archiver 2001 6 23-06-2002 23:14
Size Is Large archiver 2000 15 23-06-2002 22:47
