Go to Post We owe a lot to Bob (Hammond), he is a true gentleman. - Covey41 [more]
Unread 16-02-2004, 20:31
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: Distro block, maxi fuse box, and ground stem
the distribution block and ground stud are required for this years robots circuit
Where do you guys see in the rules where it says the ground stud is REQUIRED?
Instead of using the ground lug, we have used the center "phase 2" of the Allen Bradley Distribution block which is more than enough to hold the current in not better than crimp on ring connectors to a ground stud.
However if someone could let me know if I missed something in the rules about the ground stud "required" I'd like to read it again.
PS: Attached is a very quick sketch I did of what I mean. I hope you guys can make heads or tails of it...
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
