Go to Post If time only weren't a factor, everything would be done. - Schnabel [more]
Unread 16-02-2004, 21:10
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Question Emergency! Need Help With Ir Sensors
Hi! guys I only have 7 more days and I am not even done with my IR sensors.
* The problem I am having is Using navigate.c whenever i put navigate.c in my robot it doesn't work unless i connect the motors to PWM 3&4 and. Once I am done connecting the motors to PWM 3&4 the robot goes crazy it just goes everywhere and it doesn't move it's servon motors and doesn't detect beacon.
* When I put my Motors on PWM 13 & 15 the robot doesn't move at all it doesn't perform any movement all it does is just straightens up the sensors and that's it. The programm gives the command "MOVE TO CENTRE" but it doesn't perform the action.
* Does anyone know why I am having this troubles please help me? I am pretty much furustrated and if you want to contact me my msn is jigarjuhi@yahoo.ca and that's my e-mail so it's 2 in 1. Please help me!
Unread 16-02-2004, 21:21
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
Re: Emergency! Need Help With Ir Sensors
Ok, here goes,
What pwm's are you plugging the servos into?
Made sure that the cable orientation is correct the IR's, servos, motors, PWMs?
I'm loading up the navigate code right now!!
Suddenly being rejected from college feels right during the build season. Now I am a mentor.
Unread 16-02-2004, 21:40
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
of course it doesn't move when you plug the motors into pwms 13 and 15 - navigate doesn't output to those pwms.
if it's moving crazily when you plug them in to pwms 03 and 04 (the correct ones), then you probably need to adjust the values in the program to suit your sensors, as well as make sure the servos are hooked up correctly.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 16-02-2004, 22:18
Jigar Patel
AKA: Jigar Patel
Exclamation Re: Emergency! Need Help With Ir Sensors
Originally Posted by Ryan Cumings
Ok, here goes,
I am currently using PWM 1 and PWm 2 for servo motors
I use the IR's in Digital I/O 1,2,3,4 and motors into PWM 13 and 15.
Unread 16-02-2004, 22:30
As delta pointed out, 3 and 4 are the correct ones (how did you come up with 13 and 15?). I would just recomend leaving them unplugged or blocking up the robot to see how it acts through the debug port.
Unread 16-02-2004, 22:36
I believe the IR sensors belong on digital 1&2 and digital 4&5.
Verify by looking at the comments in the header of the receiver.c file.
The motors go on pwm3 & 4
The servos go on pwm1 & 2
Verify by looking at the code in navigate.h
Unread 16-02-2004, 22:46
rswsmay's Avatar
rswsmay rswsmay is offline
AKA: Robert
FRC #1177 (Mecha-Jags)
rswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the rough
Are you utilizing PWM 13 and PWM 15 because you are using a tank drive system?
Knowledge is only strength.... Knowledge and Wisdom, thats true power.
Unread 17-02-2004, 00:07
Computer Guy
AKA: Dav
13 and 15 would probably come from the code for single-joystick navigation in the default program.
Unread 17-02-2004, 23:45
Jigar Patel
AKA: Jigar Patel
for some reason after connection the motors to pwm 3 and 4 the robot just goes crazy it just sought of goes everywhere bashing everything. Anyone knows why?
Unread 18-02-2004, 00:28
Computer Guy
AKA: Dav
are your motor polarities correct? if one were backwards, the robot would turn when it thinks it's going forward, and go forward or back when it thinks it's turning... this would cause some really strange behavior.
Unread 18-02-2004, 08:07
I'd put it up on blocks and check the status of the IR sensor tracking.
Call the tracker alone without the navigate and print out the tracker status:
Tracker_Data[left].Status, Tracker_Data[right].Status
Also observe how the servos behave.
Does it hold on the beacon or look all over the room?
After you're sure the tracker/beacon combo are working correctly, then move on to debugging the navigator code.
Unread 18-02-2004, 12:14
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Hey,
is there a way to see if the IR / optical sensors work, i mena for the beacon you just get a camera, what is the way to c if the IR sensors are working. And whts the shipping time, if any of you have ordered new IR sensors..
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 18-02-2004, 12:29
Originally Posted by thoughtful
Hey,
There are several easy methods.
- You can just check the IR receiver buffers, see Kevin's FAQ or other posts for what to look at and how to interpret the data.
- You can disconnect the servos and printf the Tracker_Data[left].Status & Tracker_Data[right].Status, i.e., the tracker states are:
NONE_IN_VIEW 0
RIGHT_IN_VIEW 1
LEFT_IN_VIEW 2
BOTH_IN_VIEW 3
- Using a regular digital input printf the value of the sensor. In the presence of the beacon or a compatable IR source like a TV remote you will see a mixture of 1's & 0's. Bad sensors show all 1's or all 0's.
For shipping you can order overnight of course. 1st class TX to NY was a couple of days (Friday to Tuesday over a holiday).
Unread 19-02-2004, 01:11
danielkitchener's Avatar
danielkitchener danielkitchener is offline
408 Computer Nerd
AKA: Daniel Kitchener
#0408 (Roboticks)
danielkitchener is on a distinguished road
We also had similar problems with our robot going crazy with the tracking code...but then we realized our IR sensors weren't plugged in. But FYI, i think servos are supposed to plug in to PWMs 3 and 4. Your robot was going crazy because the pwm values were switching back and forth because the program thought they were servos and was sweeping the field with them...
Unread 19-02-2004, 01:16
thoughtful's Avatar
i had tht hunch dont know if it is true, but can you please point out where the motors will go than..i mean drive motors
06-Team 1219 Mentor
Interrupts and rotation sensors kor Programming 3 12-02-2004 11:05
Line tracking sensors - Wiring up? ahmed Electrical 2 09-02-2004 20:52
wiring diagram for light sensors??? pagemauck Control System 1 21-01-2004 16:32
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
