Go to Post anything that breaks a kitbot frame is probably breaking most custom frames of similar weight, too. - dtengineering [more]
Unread 16-02-2004, 20:03
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: 4-wheel drive trouble
Try wrapping a pair (one from each drive train) of tires with something radially. I understand this is kind of a dumb solution, it makes more sense to just get wheels or tires with the right treads, but its easy, cheap, and quick.
At first we tried 1/16" steel cable, but it wasnt big enough to lift the wheels off the ground. We probably shoulda have tried again with thicker cable, but that stuff is REALLY tedious to work with (think 100+ ft per pair and something like 130 individual wraps). So we had some zip tries lying around... They are excellent at reducing cross-wise friction (it turns on high gear now) but they did take away significantly from traction in the direction we need. Regardless, we can climb 6 inches with our two drills and 12.5" skyways, so im happy.
Team 1257
Unread 16-02-2004, 20:41
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
How bout this:
Replace 2 wheels with omni's...
Probably the rear wheels. This will retain your 4 wheel strength while making your turning much slicker. I also think that with a small chamfer on the front wheels should do the trick.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 16-02-2004, 21:32
occra 23.
AKA: ryo
None #1481
Originally Posted by Sachiel7
How bout this:
are there any off the shelf 12 in omni or transwheels? i'd love to have them. never seen any big sized ones tho. probably too heavy. we can't machine our own, but id really like them
Unread 16-02-2004, 21:48
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
Why not try zip ties? They're cheap, slick, durable, and quick to install!
Unread 16-02-2004, 21:51
Originally Posted by Joe
we have to deliver our robot thuesday (because of the carnival holidays)
Is that tuesday or thursday?
Unread 16-02-2004, 22:02
#0246 (Overclocked)
It is both, yet neither.
Unread 16-02-2004, 22:03
Fold em oval!
Please read my whole post....
Zip ties are really a half-assed solution. They kill probably more than half of your forward traction for the wheels you put them on.
Team 1257
Unread 16-02-2004, 22:47
Sachiel7's Avatar
AKA: Shayne Helms
Well, I didn't have much luck finding an actual 12" omni... but...
You could make a small plate (doesn't even need to be circular) and bolt or lock an omni at each corner. Basically you're making a bigger omni with off the shelf omni's that are smaller. All it means is that you need more small ones.
You should be able to do this with common tools.
-=Sachiel7=-
Unread 17-02-2004, 20:04
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Another solution that does not involve changing you robot dimensions or wheels is to place more wieight on either the front or rear wheels. If either end has more weight than the other, you will be able to turn easier because the heavy end will have more traction than the light end, and will be able to slide the light wheels around the corner.
Unread 17-02-2004, 20:40
Dick Linn's Avatar
no team (Synergy)
Quickest way is to lose some traction from one end or the other. Any chance at resurfacing one set of wheels with something slipprier? Possibly the edge profile is very square and sharp, and will snag more than slide when you are trying to pivot sideways. If you can bevel one or both sets of wheels to a more rounded profile it could help. We did the 2:1 gearbox last year and had to combine one pair of the sticky pneumatic Skyway wheels with one pair of the (slipprier) Polyurethane wheels, but it was still very difficult to turn with about an 18 inch wheelbase. It required a different driving style. Sometimes we had to actually reverse one side while driving forward on the other in order to get it to turn. I couldn't get it to turn well while driving normally, but some could do it while another sat on top...on pavement!
Beautiful craftsmanship on your robot, by the way. Love it!
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 17-02-2004, 21:53
Geoff Geoff is offline
h4x0r sup3r10r
#0246 (Overclocked)
Geoff is an unknown quantity at this point
Send a message via ICQ to Geoff Send a message via AIM to Geoff
Stop stealing my lines.
Unread 17-02-2004, 22:05
samson234's Avatar
samson234 samson234 is offline
Head Lathe Operator
AKA: Sam Harding
FRC #0234 (Cyberblue)
Team Role: Driver
samson234 will become famous soon enough
It may sound bad but it truly works...or at least it did for my team.but of course if you can find an Omni or more torque in your drive you would want to go with that and only use zip ties in a last minute, between matches solution
"It takes a little over an hour."
Unread 19-02-2004, 12:08
pryoplasm's Avatar
pryoplasm pryoplasm is offline
Pit Crew/Electrical
AKA: Russ
#0069
pryoplasm can only hope to improve
it might be helped if you also describe how you are turning it. if you have 2 joysticks for each of the sides for tank drive, are you moving one back on the y axis, while moving the other forward on the y axis?
our team had a similar problem a while back, and what helped was with the drivers, instead of full forward and full backwards on both sticks, alternate the sticks, going one forward, and the other backwards, it will be a slightly slower turn, but it might help.
Cut these eyes, but I will see,
Kiss these lying lips for me,
Stroke this skin, and I will kneel,
Brutalize me, I will heal...
-KMFDM
Unread 20-02-2004, 14:16
Guilherme's Avatar
Guilherme Guilherme is offline
Guilherme Balbinot
AKA: Guilherme Balbinot
Guilherme will become famous soon enough
Send a message via MSN to Guilherme
Problem solved, check this thread
http://www.chiefdelphi.com/forums/sh...ad.php?t=25482
thank you all !
Guilherme Balbinot
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
Tank Stearing - 4 wheel drive Joe P Technical Discussion 12 04-03-2003 23:05
wheel drive Greg Needel Technical Discussion 3 29-01-2002 12:12
