Go to Post Ineveitably what we do just might end up in the hands of millions of people. - JoeXIII'007 [more]
Unread 16-02-2004, 22:32
Brawler006 Brawler006 is offline
#1206 (Wrench Warriors)
Brawler006 is an unknown quantity at this point
wiring solenoids
Does anyone know how to wire a double solenoid (from smc) to a spike, and then to a breaker panel? Thanks
Unread 16-02-2004, 22:35
Re: wiring solenoids
1)wire one side's positive (red) wire to the relay FWD output. With the ground wire to your ground.
2)Wire the other sides positive wire to relay REV. Wire ground to ground.
3)Switch relay with buttons
4)Voilla.. you have movage
Unread 16-02-2004, 22:40
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
You can wire the double selenoids in that way, or you can wire it to 2 relays as my team did last year.
To wire it to 2 relays, wire the postive/negatives on 1 side of the selenoid to the postive/negatives on the relay, and the other side of the relay, positive to a breaker and the negative to a ground. Wire the other side of the selenoid in the same way.
Both ways mentioned will work, it's just a matter of preference.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 16-02-2004, 23:02
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
If you want to avoid having a separate ground return wire, do it this way:
Connect the cathode of a 1N4001 or similar diode to one red lead. Connect the anode of another diode to the other red lead. Connect the anode of the first diode and the cathode of the second to the M+ terminal on a Spike, and connect both of the black leads to M-. This method has worked well for me.
Unread 22-02-2004, 19:28
Charley's Avatar
Charley Charley is offline
Alumnae, Capt v2 for ever.
None #1350
Charley is on a distinguished road
Send a message via AIM to Charley
Is there a maximum PWM wire connecting the solenoid to the spike? We just fried ours, and want to step it up : ).
Thanks,
Charley.
Team 1350
Manchester 2003 Rookie All Stars
Unread 22-02-2004, 19:32
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Thanks,
Charley.
If your talking about how many solenoids can be wired to each spike, that number is one. All though (as the 2004 wiring diagram shows) you can wire upto 3 solenoids each through their own spike to 1; 30 amp fuse on the breaker.
-Michael Dessingue
Unread 22-02-2004, 19:42
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
we have had great sucess with the diode method. however i was wondering if there was a way, using 1 standerd double solonoid valve and a piston, to stop the piston mid-stroke electronicly? our arm group wants me to do this in the wireing and i have no idea how to even begein.
"You're not a real programmer until all your sentences end with semicolons;"
Unread 22-02-2004, 20:26
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
There is actually no way to stop a piston's throw electronically, it depends totally on air pressure. You can slow it down a great deal using the special valve fittings FIRST supplied.
Give this thread a read-through if you want to do multi-positioning pneumatics.
http://www.chiefdelphi.com/forums/sh...ad.php?t=23934
Unread 22-02-2004, 20:46
AKA: theshadow
FRC #0620 (WarBots)
that is an amazing thread.
Unread 22-02-2004, 20:55
Paradox1350's Avatar
Paradox1350 Paradox1350 is offline
FORMER Captain now Jealous Onlooker
None #1350 (Rambot)
Paradox1350 is on a distinguished road
What my team mate (Charley) was saying is that we went to use our pneumatics and the wiring smoked. Literally, smoke was coming from the wires connecting the spike to the solenoid. We used really thin guage wire to connect our solenoid to our spike. We changed to a MUCH larger actuater today. Before today, pneumatics worked FANTASTIC. After the step-up in actuater size, we went to test it, and the wires between the spike and the solenoid fried. What gauge should we use, ideally?
Unread 22-02-2004, 21:06
AKA: theshadow
FRC #0620 (WarBots)
our team uses the 4 conductor 22 gauge wire that comes in the kit. i wired the red-white together and the black-ground together. this has worked perfectly. but if you were going for an ideal gague, i would say about 18, mabye 20. 16 is far to large
Is there any restrictions on buying solenoids hello world Electrical 1 01-02-2004 12:04
solenoids from last year Antonio Pneumatics 6 29-01-2003 22:59
Optical sensor wiring with the EDU Robot Geoffrey4283 Electrical 3 15-01-2003 21:03
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
solenoids zarb Electrical 1 28-01-2002 23:19
