Go to Post My favorite is always "The Next One!" - Bill Moore [more]
Unread 16-02-2004, 20:30
patTeam241 patTeam241 is offline
College Student
AKA: Pat Cleary
patTeam241 will become famous soon enoughpatTeam241 will become famous soon enough
Send a message via AIM to patTeam241
Question Inventor (*.ipt) -> Dxf
For a stress analysis program I'm using I need *.dxf (one of autodesk's formats). Is there any way to get inventor files into this type?
Thanks
Pat
Unread 16-02-2004, 21:34
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
Re: Inventor (*.ipt) -> Dxf
if inventor can (im pretty sure it can) open the file you want then go to save copy as and in the pull down menu u can choose a wide variety of formats. hope this helps
-matt
Unread 16-02-2004, 21:56
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
You can save an Inventor .ipt as .dxf using the Save File As command (File menu). I don't have Inventor in front of me, but I believe that you just select the file type in a scroll list box at the bottom of the Save As dialog.
Post again if you still have difficulty.
Pete Kieselbach
Unread 16-02-2004, 21:57
well if we both agree it must be right
Unread 16-02-2004, 22:07
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Actually, you can't save an ipt file as a dxf. Unless it was added in version after 6. You can howerver save a Drawing file (idw) as a .dxf.
Purdue Alumni
Cummins, Inc.
Unread 16-02-2004, 23:09
petek's Avatar
What would Dave do?
Oops! Clark's right - you'll have to make a 2D drawing of the part (a .idw) and save it as .dxf. You can save a .ipt as .igs (solid or wireframe), if that helps.
Pete Kieselbach
FIRST-SME membership archiver 2001 5 24-06-2002 00:41
ps and pdf to dxf ??? archiver 2000 0 24-06-2002 00:17
ps and pdf to dxf ??? archiver 2000 2 24-06-2002 00:17
My round of thank-yous... archiver 2000 2 23-06-2002 22:57
