Go to Post Mark McLeod, one of the resident experts on compiler weirdness - Kevin Watson [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 01-02-2002, 00:45
smokescreen smokescreen is offline
FRC #2360 (POWERStorm)
Team Role: Photography
smokescreen is on a distinguished road
Bloody control system
I hate this bloody control system.
No interrupts.
Not enough ram.
Can't send every variable to the dashboard.
UNSIGNED INTERGER MATH!!!!
Have to check on certain issues in the rule book, however.
Input and output is handled by the robot controller.
The OI sends signals to move servos.
Pots are connected to these servos.
Digital outputs turn on LEDs
The output of these LEDs are fed by phototransistors into the custom circuit board.
The pots, limit switches, and various other sensors hook into the custom circuit board.
The PIC in the custom circuit board handles the "thinking" part of the operation and sends voltage signals back to the OI through the sensor port.
These voltage signals are direct sensor signals to give values from 0-255.
The OI then simply reroutes the sensor signals to the appropriate speed controller or relay.
Ha! No more bloody stamp.
Goodbye Pbasic!
Nothing but good old assembler.
No! Don't let the MWS out!
Unread 05-02-2002, 14:20
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
You are right, brotha...
At least the little Lego robotics can be programmed in IC (Interactive C)...
I hate PBASIC...
And I'd gladly learn ASM (x86, if possible) instead of having to work with PBASIC...
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 05-02-2002, 19:22
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
*COUGH* $100 Custom Circiut Board *COUGH*
*COUGH* Embedded System *COUGH*
*COUGH* Pick your architecture *COUGH*
...so stop complaining!
Just got my 68HC11F1CFN2 from Digi-Key yesterday. I'll post pictures of the board doing somthing that will shock and amaze soon!
Unread 13-02-2002, 20:11
Joelster Joelster is offline
#0758 (Roboticats)
Joelster is an unknown quantity at this point
A program that may help
It is to make an arm turn if u or anyone else needs it. Any questions just pm me!!!!
if logged = 1 then hopskipjump:
if count1 = 1 then skippy:
if p1_sw_top = 0 then out:
if p1_sw_top = 1 then in:
in:
relay1_fwd = 1
relay1_rev = 0
count1 = 1
goto hopskipjump:
out:
skippy:
if count1 = 0 then jumpy:
if p1_sw_top = 0 then outy:
if p1_sw_top = 1 then iny:
iny:
relay1_rev = 1
relay1_fwd = 0
count1 = 0
outy:
jumpy:
hopskipjump:
logged = p1_sw_top
Unread 18-02-2002, 21:11
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Yeah, it would be great if there was an alternative control system. Even if you do make your own, you have to interface it with the IF one.
I guess FIRST is more interested in mechanical innovation then computer & electronics innovation. Too bad.
Unread 26-02-2002, 01:37
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
When I was your age, we had to carry arounch punchcards and walk two miles to the nearest computer only to find a mistake in our algorithm and ...
ah nevermind.
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Unread 26-02-2002, 02:17
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
I have to agree with FotoPlasma. I have a lego robot running a HandyBoard with a 68HC11 core, and I program it in InteractiveC. I'm telling you, the multithreading alone makes IC a godsend.
Zan Hecht
Unread 26-02-2002, 02:29
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Ahh..but do how far can you optimize your code?
Anyone else using bitshifts?
Viva Olancho!
Unread 26-02-2002, 08:04
Mine always worked perfectly the first time...of course there was the problem of dropping them
Unread 07-03-2002, 13:07
Greg McCoy's Avatar
boiler up!
Maybe in 10 years we'll be saying:
"And we had to use Microsoft products..."
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
UNFAIR ADVANTAGE for CDI and new control system archiver 2000 6 23-06-2002 22:13
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
