Go to Post You know you've overdosed on FIRST when you hear people yell "CHARGE" and you get confused and lost when you look and see baseball and not robots - thatphotochick [more]
Unread 17-02-2004, 00:22
Paul Marshall Paul Marshall is offline
Paul Marshall will become famous soon enough
Send a message via AIM to Paul Marshall
Female PWM cable connector
Does anyone know where I can find specs (specifically the dimensions) of the female PWM cable connectors?
-Paul
Unread 17-02-2004, 01:46
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Female PWM cable connector
From the magical FAQ:
Q: Which connectors did you use to connect to the robot controller?
A: If you really, really want to build your own cables and haven't consumed any caffeine in the last week, use Amp connector housing P/N 530554-2 and female contact P/N 530553-5.
Digi-Key has 'em. Search on P/N 530554-2-ND for the connector housing and P/N 530553-5-ND for the contacts. If you decide to build cables using this connector, make sure you have a good set of needle-nose pliers for crimping. I also recommend a very small dab of solder for a good connection.
-Kevin
Kevin Watson
http://kevin.org
Unread 17-02-2004, 02:04
I can't remember exactly, but I thought the PWM cables that FIRST gave us had a chamfer on one of the corners and possibly a tab on the short side so that they can't be inserted in the wrong orientation. Is my memory leaving me or am I right. If the cable connectors do in fact have those features, does anyone have dimensions on them. BTW, thanks for those specs.
-Paul
Unread 19-02-2004, 12:10
pryoplasm's Avatar
pryoplasm pryoplasm is offline
Pit Crew/Electrical
AKA: Russ
#0069
pryoplasm can only hope to improve
yeah, they have something along those lines, but speaking as a stubborn person who has to deal with PWM cables in the pits, if you try hard enough, it can fit in, chamfer or no chamfer....
Cut these eyes, but I will see,
Kiss these lying lips for me,
Stroke this skin, and I will kneel,
Brutalize me, I will heal...
-KMFDM
LEGO IR tower cable Jeff Rodriguez Chit-Chat 1 31-10-2003 16:23
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Unsafely securing Anderson connector? Andy A. Electrical 20 16-04-2003 22:11
Loss of signal in PWM cables. archiver 2001 6 23-06-2002 23:29
