Go to Post The programmers tend to get less credit than they deserve, but the robot wouldn't run if we weren't there. :) - IMDWalrus [more]
Unread 17-02-2004, 10:54
Re: Will plexi-glass work?
thsi late in the season I recommed you use 3/8" plywood for the base and the 2x4 alum pieces that FIRST gave your for the sides.
we built a pratice robot like this in november with parts left over from last year. It only took us 3 one hour meetings, at the highschool, to put it together and get it running
Im certain you could do the same in one weekend.
Unread 17-02-2004, 11:56
Generator of Entropy
FRC #2973 (The Mad Rockers)
Sorry to hear about your problems, but don't throw in the towel yet. It's easy to get overwhelmed, especially in your rookie year, with trying to do too much and seeing alot of things fail. You still have over a week left - see what you can do positively. Ken's idea about plywood and kit parts is a good start - get something driving so you can get some practice. A moving robot is an asset in any match - you can certainly block your opponent's corral and you can push balls even if one at a time. Use the default code - go back to square one and take smaller steps.
BTW - when you get to the competition I think you'll be surprised at how supportive other teams are. No-one will look down on you if your robot is dead, in fact they'll pitch in and try to help you get it started. You will enjoy this event regardless of how you robot performs.
Our rookie robot was named "Kenny" because it got killed every match. But we learned alot and moved on.
And don't use plexiglass/acrylic. Use Lexan/polycarbonate.
Unread 17-02-2004, 12:35
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
if you go with lexan instead of plexiglass ask for polycarbonate - same stuff much cheaper.....gl
Unread 17-02-2004, 13:05
caffel caffel is offline
AKA: Charlie Affel
FRC #0423
caffel is an unknown quantity at this point
There is only one plastic strong and tough enough. LEXAN.
All, that is All of the other and cheaper choi ces will crack and let you down. I can tell you this after 4 years of experience.
Charlie Affel,
Mentor 423
Unread 17-02-2004, 13:12
Ryan Albright's Avatar
Ryan Albright Ryan Albright is offline
Just Browsing
AKA: ryan albright
Ryan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond repute
Send a message via ICQ to Ryan Albright Send a message via AIM to Ryan Albright Send a message via MSN to Ryan Albright Send a message via Yahoo to Ryan Albright
any chance of using lexa or plexiglass for a base is nto good. I am guess you are a rookie team. We use lexan to protect the compenents of our robot and for skins. Lexan is strong but not made to be a base. I would not quit yet but i would suggest go get some wood like mentioned about and just build it out of wood. Especially with a game that i think is gonna involve alot of contact between robots like last year youa re gonna need somethign that holds up
Alumni of 710 2001-2004
Mentor 1083 2005
2005 UCF regional lead safety advisor
2005 Championship Safety advisor
Unread 17-02-2004, 13:31
Scott England Scott England is offline
FRC #0118 (The Robonauts)
Scott England is a name known to allScott England is a name known to allScott England is a name known to allScott England is a name known to allScott England is a name known to allScott England is a name known to all
Didn't plexiglass(acrylic) used to be illegal on FIRST robots since it is so brittle? I know some acrylic got mixed in with our excess stock of polycarbonate, found out the hard way when it shattered while trying to be bent. Eitherway, polycarbonate frames have been done before. In 2001 we had a robot with no structural metal
Browsing the gallery, it looks like team 49 also did a robot made primarily out of lexan
So yes its possible, given your time crunch though, wood might be easier to get and to work with. Just get a drive train that runs first and go from there, there's still plenty of time left. Good luck,
~Scott
122 --> 401 --> 118
"The Earth is a very small stage in a vast cosmic arena. Think of the rivers of blood spilled by all those generals and emperors, so that, in glory and triumph, they could become the momentary masters of a fraction of a dot. Think of the endless cruelties visited by the inhabitants of one corner of this pixel on the scarcely distinguishable inhabitants of some other corner, how frequent their misunderstandings, how eager they are to kill one another, how fervent their hatreds. Our posturings, our imagined self-importance, the delusion that we have some privileged position in the Universe .... In our obscurity, in all this vastness, there is no hint that help will come from elsewhere to save us from ourselves. "
Carl Sagan
Unread 17-02-2004, 13:40
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
I agree, if you absolutely must use a plastic, use lexan. It is more durable, and while it does splinter and shatter, it is less likely to do besides plexiglass. If you use this, you have to support it, using plexiglass or lexan will no support is a sure way to have a base be totally demolished. Supporting the base with aluminum extursion at stress points (if you can, ask an engineer to evaluate your design and offer advice on where to support it) is a very good idea.
Now Ken is also right. There is absolutely nothing wrong with using plywood as a base. In fact, one team that comes to mind that uses a wood base every year and is one of the well known teams in FIRST is Team 173 Rage. Every year they use a wood frame (which I'm not mistaken is supported by aluminum brackets). It may splinter, but with the brackets, it's an easy fix. Just put a sheet of aluminum or steel over it, bolt it on, and you're ready to go. I bring up Rage, because they are one of the well known teams that uses a wood base, and have so for years.
And yes, if you turn up at your regional with your robot unfinished, it's guarenteed other teams will come over to help you. No team is going to look down upon you, in fact most teams will do everything in their power to make sure your robot works and is able to compete. That's the great thing about FIRST, everyone is willing to help each other to make sure the competition is as good as it can be and everyone has a fighting chance.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 17-02-2004, 13:48
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
I don't know how physical this years matches will be but last year we shattered the side of a lexan robot in our first practice match (they ran into us). I still have a piece of it.
I would use wood and the aluminum for the kit. You can definitely get something driving and it will cut down on the repairs you will have to do at competition. You can compete if you can make something that can drive every match.
Unread 28-02-2004, 21:53
tenfour's Avatar
tenfour tenfour is offline
AKA: Chris
#0696 (The Circuit Breakers)
tenfour will become famous soon enough
Send a message via AIM to tenfour
You all are crazy. Lexan can't be shattered, or damaged. Maybe if you buy it down at the local rip off house home imporvement store, it will.
Horray for Lexan!?!?!?!
-2004 Arizona Regional Finalists (thanks 80 and 498)
-2004 Arizona Regional Sportsmanship Award
-2003 Los Angeles, CA Regional Finalists
-2003 Phoenix, AZ Regional Semifinalists
-2003 Phoenix, AZ Regional 3rd Seed.
-2002 Los Angeles, CA Regional Semi-Finalists
-2001 Los Angeles, CA Regional Semi-Finalists
FIRST Mantra - When Lawyer-ism fails, Gracious Professionalism Prevails.
(Yes, it is "BCR Orange")
Unread 29-02-2004, 02:44
maclaren maclaren is offline
AKA: Dexter
FRC #0997 (Spartan Robotics)
maclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of light
I have seen lexan shatter but it takes quite a bit to shatter it. The circumstance was in battle bots. A spinning bot got slammed in to the 1/2" thick bullet proof lexan wall and took a chunck out of it the size of a human head. It was pretty spectacular.
But that is way out of the FIRST robotics league.
Unread 29-02-2004, 04:05
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
This is team 1038 from 2003.
http://www.chiefdelphi.com/forums/pi...gle&picid=3592
I Hate Signatures!
Unread 29-02-2004, 09:13
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Lexan can easily be damaged. The sun is just one of the many things that can and will weaken it. Loctite is another.
Unread 09-03-2004, 22:48
Kaelia's Avatar
Kaelia Kaelia is offline
The one with evil hair
AKA: Christina Xu
#0677 (WireStrippers)
Team Role: Driver
Kaelia is on a distinguished road
Send a message via AIM to Kaelia
Polycarb + Heat gun = Messy death. We tried to bend it like that for our control box last year. Oooops.
Other than that, it is a great material to use...however, I don't see why there is so much worry about break-age. The competition this year really isn't as violent as last year's, and I personally think you'll be just fine with Plexi unless you're planning on playing bumper cars with the other bots...
The Enemy's Gate is Down
Got Anton's Key?
~~Base 8 is just like base 10, really...if you're missing 2 fingers! - Tom Lehrer~~
I SURVIVED the VCU Viral Outbreak!
Team 677 - Living proof that Team Spirit is more than mascots, banners, ear-splitting noisemakers, skimpily-dressed cheerleaders, and/or constant obnoxious cheering.
Unread 02-04-2004, 15:15
Phasmatis568's Avatar
Phasmatis568 Phasmatis568 is offline
Electrical/Programer
#1038 (Thunderhawks)
Phasmatis568 is on a distinguished road
Originally Posted by Eric Bareiss
Our entire base was constructed of lexan. With this we managed to hold up against anyone who tried to push us off the ramp.
This year our robot used lexan plating on an aluminum frame. We decided to play king of the hill on the chin-up platform. The lexan on our robot is merely scratched. You dont have to worry about it breaking in this competition.
Unread 08-04-2004, 02:09
Grommit Grommit is offline
#0115 (Monta Vista Robotics)
Grommit will become famous soon enoughGrommit will become famous soon enough
Send a message via AIM to Grommit
I don't want to repeat anything that's already been said... so I won't mention plexi-glass and the fact that it is completely horrible for use as a structural component on a robot.
But I will say something interesting: We have a cart we've been working on, which is motorized, to carry the robot around on. We gave our 12" wheels to team #1043 before we realized that we might have wanted them for the cart. (A good move, they made very good use of those wheels). However, to get to the point, we actually tried replacing those wheels with 12" roughly cut wheels of lexan instead. Ugly, but they could withstand the pressure, and weight isn't an issue for a cart. We will end up putting the pneumatic tires on, but the cart would have functioned, we expect, with the lexan.
Shrenik Shah
Engineering Director
Team 115: Monta Vista Robotics
Congratulations to Mr. Shinta for winning Woodie Flowers at Silicon Valley!
Problems of the mind... effecting work Gadget470 Chit-Chat 20 18-11-2003 11:56
Edit doesn't work on original title posts??? Elgin Clock CD Forum Support 6 12-03-2003 17:30
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
