Go to Post (Yes, I'm that much of a dork.) - Madison [more]
Unread 15-02-2004, 00:50
Fat Alex's Avatar
Fat Alex Fat Alex is offline
Mr. super uber ultra Alex
AKA: Alex
#0060 (Bionic Bulldogs)
Fat Alex is on a distinguished road
Send a message via MSN to Fat Alex
ruber bands and drill motors
What exactly is the purpose of the rubber bands that come with the drill motors?
Unread 15-02-2004, 00:58
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: ruber bands and drill motors
I believe it's to hold them in either high or low gear.
A zip tie will work well too, however.
Good luck!
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 15-02-2004, 03:27
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I believe it is to hold in the shifter clips.
Unread 17-02-2004, 10:24
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
I have no clue!!!!
The easiest way to lock the trans into low is to pop of the black part that goes over the motor rotate it 90 degrees then put it back on
P.S. Found that out last year by accident at the buckeye regional. LOOOOOOOOOONG STORY
"I'm sorry, after all he is just a wookie!"
Unread 17-02-2004, 13:48
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
If the clip does pop out, can i just push it back in? This happened to us and we think the shifter may be not engaging when it is supposed to be. Is that related?
Team 1257
Unread 17-02-2004, 13:53
ngreen ngreen is online now
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Your in bad shape when the clip pops out. This is what the rubber band is for and I urge everyone to use their. We already lost a transmission because the zip ties we were using loosened up and the pin popped out and the place shifter broke. Use the rubber band to hold the clips in place and use zip ties to keep the shifter in place. It the clips do pop out you will have to look at the motor diagrams, I think their is on in the white paper, because I don't think it works quite right if you just pop the pin in.
Unread 17-02-2004, 14:06
<sarcasm> These rubber bands serve a far more important purpose. They are to be used instead of screws, bolts, super glue, duct tape, or whatever you wanted to mount your motors with. This can be achieved by creating a simple figure 8 with the band, wrapping one side around the motor, and the other around some kind of shaft </sarcasm>
Unread 17-02-2004, 14:11
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
Now while this may seem like a good idea, remember that rubber bands can snap really easily, so it's not advisable hehe.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
