Go to Post I will gladly be pied if that's something you guys want. I know I have people from the Clarkson FIRST dorm floor who will shell out PLENTY of cash for the chance to pie me in the face! - Libby K [more]
Unread 17-02-2004, 13:52
Jeff McCune's Avatar
Jeff McCune Jeff McCune is offline
Alpha Geek
#0677 (The Wirestrippers)
Jeff McCune is on a distinguished road
Send a message via ICQ to Jeff McCune Send a message via AIM to Jeff McCune
Re: Programming Help
Originally Posted by steven114
If you want it to move exactly 270 degrees, you will need some sort of feedback system. I would recommend a pot - do you know how to wire one up?
You need to read the 2004 Programming Reference guide located here:
http://www.innovationfirst.com/FIRST...10-29-2003.pdf
You also need to read the 2004 FRC Default Code Reference Guide:
http://www.innovationfirst.com/FIRST...e_2004-1-7.pdf
The second PDF document explains in detail what's going on in the default code that Innovation First provides.
Team 677 - The Wirestrippers - Columbus School for Girls and The Ohio State University
EMAIL: mccune@ling.ohio-state.edu
...And all you touch and all you see
Is all your life will ever be...
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
A few questions on programming the Control System Avarik Control System 21 08-02-2004 11:42
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
pbasic programming punarhero Programming 4 21-01-2002 23:32
