Go to Post The programmers tend to get less credit than they deserve, but the robot wouldn't run if we weren't there. :) - IMDWalrus [more]
Unread 17-02-2004, 15:53
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
Re: Piston throw control
Actually, if you follow the flow chart, you cannot use any off the shelf solenoids.
Electronics (yes) -> Is the part a motor, solenoid, pump, or other actuator? (yes) -> No, it may not be used.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Piston throw Alex N. Pneumatics 2 21-01-2004 21:19
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
Some code in C that we may need if we are in trouble Andrew Rudolph Chit-Chat 16 07-10-2003 21:34
how do i control a piston with a joystick Ryan Foley Programming 2 27-05-2003 17:13
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
