Go to Post The amount of sense this rule makes is irrelevant. It is still the rule, and breaking this rule violates something that i'm sure all of you have heard of. Does gracious professionalism ring a bell? - Kate00 [more]
Unread 17-02-2004, 16:22
Tomas's Avatar
Tomas Tomas is offline
FRC #0383 (Brazilian Machine)
Tomas is a jewel in the roughTomas is a jewel in the roughTomas is a jewel in the roughTomas is a jewel in the rough
Send a message via ICQ to Tomas Send a message via MSN to Tomas
Re: What to do with autonomous
Originally Posted by RoboCoder
Since the line is much less "Curvy" this year, line following could be optimized to go faster than last year. HOWEVER, I would strongly recommend against that if possible. In many applications, not just FIRST I have tried line following and have not been satisfied with the results. Most of the time it is either too slow or loses the line too easily. Granted, there are applications where line following IS a very viable option, but I'm pretty sure that this is not one of them, especially since FIRST gives you the sensors and code to use the IR beacons, especially since they seem determined to make sure they are fully utilized in the future. So, of course, ultimately it is up to the individual teams, but personally, if you ask me, then it is not your best option.
I made some tests following the line, actualy, many of them. The best results came out using six sensors! Use them in V, and put them as far as you can from the robot's rotation center, keeping a distance of 6'-7' between the center sensors, so the robot can go with two or three corrections only. In 30 times we got there everytime between 7 and 8 seconds, never loosing the line. The limit is your drive system!
Tomás Fiori
Coach & Mentor
Team #383 - The Brazilian Machine
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
Electrical componenets for autonomous navigation maclaren Electrical 10 18-12-2003 02:28
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
