Go to Post Gracious Professionalism at its finest - Competing like CRAZY on the field, then working together like professionals off the field to make these events the best they can be for everyone involved. - Stu Bloom [more]
  #46   Spotlight this post!
Unread 26-01-2004, 22:24
IrisLab's Avatar
IrisLab IrisLab is offline
AKA: Dave Page
#1466 (Webb School)
IrisLab will become famous soon enough
Re: What to do with autonomous
Originally Posted by Mike Soukup
Because we tried it and it worked the first time Seriously, we chose 6" because we figured that it got us "close enough" to our point. Last year's game didn't require much precision, just a quick turn and dash up the ramp. If we were a couple of inches off it didn't really matter much. We wanted to run full speed the whole time and not worry about going back to a waypoint if we overshot it. We didn't do much testing, we just picked a box that was big enough to work. We made this number configurable per waypoint so changing it just required updating the range in our waypoint list.
Did you use a PID algorithm to get to a waypoint? It seesm like this would take care of overshoot.
Just curious.
David Page
  #47   Spotlight this post!
Unread 27-01-2004, 14:43
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Originally Posted by MichalSkiba
First off, a question about the uber-accurate Wildstang Positioning System (WSP perhaps?):
It was WPS originally, but we ended up dubbing it StangPS
How were you able to account for wheel slipping?
Very good question. Our system had no slippage detection/correction. (read on...)
This would occur when your robot would be pushed (while wheels were locked) or sliding down the ramp (for example).
It was more of a problem on the ice (HDPE) and performing turns on the ramp.
Like Mike said in a previous post, we didn't need a whole lot of precision. If we wanted to ram a stack (whether freestanding or the group on the ramp), we just had to make sure that the stack ended up in front of our robot.
Our wheel slippage (in normal situations) was
* minimal on the carpet in normal situations
* slight climbing the ramp
* measurable on the ice (HDPE)
* negligable descending the ramp
Therefore, we didn't design programs that spent significant time on the ice. Our double-hit program (hit the left side of the stack, come back, hit the right side of the stack) consistently cleared a good portion of the bins, but was slightly inconsistent due to the slippage on the ramp.
In situations where we came head-to-head with another robot, there was a good chance that we deflected during the collision and recorrected our heading to squeeze past and continue on. If is was the type of collision that stopped us dead in our tracks, that was a different story. Luckilly, those types happened on the ice which allowed our wheels to slip and not burn motors.
I'd immagine that such 'small' inaccuracies could addup to more then +/- 1-inch by the end of the match.
You are correct in saying that the inaccuracies would add up, but after the 15 seconds were up, the knowing our position wasn't extremely important. Had it been, we would have probably considered determining the slippage and corrected.
  #48   Spotlight this post!
Unread 27-01-2004, 16:23
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Just curious.
When you boil our algorithm down to its lowest level, it was actually quite simple: point the wheels toward the target and drive. We had a bunch of other nice features like the ability to change the robot's orientation or keep a specific orientation as the robot moved, different speeds for each leg of the path, different waypoint sizes so we could drive by quickly & not worry about hitting the point exactly, and the ability to independently move our wings at each waypoint.
But the basis of the algorithm was knowing our current position (from our custom circuit) and the position of our next point, then using some trig to get the angle to the target. After we got the target angle we figured out what angle we needed to turn our wheels to by subtracting or adding the target angle and our robot's angle relative to the field (also from the CC). This calculation ws done each time we executed our main loop, which turned out to be 3-4x slower than the 26ms IFI loop.
The theory was simple, but getting it to work consistently with the tools IFI gave us was difficult. And keeping all the PBASIC code readable & understandable was a big challenge.
  #49   Spotlight this post!
Unread 17-02-2004, 16:22
Tomas's Avatar
Tomas Tomas is offline
FRC #0383 (Brazilian Machine)
Tomas is a jewel in the roughTomas is a jewel in the roughTomas is a jewel in the roughTomas is a jewel in the rough
Send a message via ICQ to Tomas Send a message via MSN to Tomas
Originally Posted by RoboCoder
Since the line is much less "Curvy" this year, line following could be optimized to go faster than last year. HOWEVER, I would strongly recommend against that if possible. In many applications, not just FIRST I have tried line following and have not been satisfied with the results. Most of the time it is either too slow or loses the line too easily. Granted, there are applications where line following IS a very viable option, but I'm pretty sure that this is not one of them, especially since FIRST gives you the sensors and code to use the IR beacons, especially since they seem determined to make sure they are fully utilized in the future. So, of course, ultimately it is up to the individual teams, but personally, if you ask me, then it is not your best option.
I made some tests following the line, actualy, many of them. The best results came out using six sensors! Use them in V, and put them as far as you can from the robot's rotation center, keeping a distance of 6'-7' between the center sensors, so the robot can go with two or three corrections only. In 30 times we got there everytime between 7 and 8 seconds, never loosing the line. The limit is your drive system!
Tomás Fiori
Coach & Mentor
Team #383 - The Brazilian Machine
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
Electrical componenets for autonomous navigation maclaren Electrical 10 18-12-2003 02:28
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
