Go to Post Mentors can always use mentoring. - JaneYoung [more]
Unread 10-02-2004, 09:30
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
Urgent, need help asap!!
Hi,
I am currtenly working on the robot and there is a disagreement about the number of drill motors allowed to be used. I saw nothing in my fast sweep of the manuel. Am i allowed to use more than 2 drill motors?
Thanks alot
Marcus
219
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
Unread 10-02-2004, 09:33
NateBot16 NateBot16 is offline
#0528 (Dark Knights)
NateBot16 is on a distinguished road
Send a message via AIM to NateBot16
Re: Urgent, need help asap!!
You may only use the number of motors in your kit. Since there were 2 drill motors, you may only use 2 drill motors.
Unread 10-02-2004, 10:55
M. Hicken's Avatar
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
Re: Urgent! How many motors can we use?
thanks alot nate, man, there goes my design
Unread 10-02-2004, 13:18
EIROBOTICS86's Avatar
EIROBOTICS86 EIROBOTICS86 is offline
#0311 (Red Jammers)
EIROBOTICS86 can only hope to improve
Send a message via AIM to EIROBOTICS86
use the cim motors as a replacement for two drills. They run at about the same speed.
Unread 10-02-2004, 13:29
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
The CIM motor does NOT run at the same speed as the Drill motors, with or without their transmissions. Please refer to any of Paul Cipioli's posts for the comparision. Roughly, the Drill motors run at 450 RPM and 1000 RPM with the transmission and 20000 without. The CIM motor run at 5500 RPM. Those are not close enough to match without some gearing.
Unread 10-02-2004, 14:06
engineers work in orders of magnitude, so 4X faster is 'about the same speed'
10X faster or slower is 'significantly different' :c)
Unread 10-02-2004, 14:09
Alavinus's Avatar
AKA: Andrew LaVinus
It depends on where you work. I work in a lab in research and 4X can be huge. For the purposes of FIRST, you still would have much greater efficiency and overall effectiveness if you gear down the CIMs to match the Drills
Unread 10-02-2004, 14:14
you definately need to match the gearing so the torque speed curves match up. My point was with a 4X difference you are in the ball park, and can play with gear ratios or wheel sizes to get there
Unread 10-02-2004, 14:47
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
You are correct, they do not run at the same speed. However, they put out approximately the same PEAK POWER. Therefore, if you do your gearing right, you should get the same output out of the drill or the CIM.
-Chris
Unread 17-02-2004, 17:39
BillyGoats BillyGoats is offline
Paper Eater
None #0061 (Intimidators)
BillyGoats can only hope to improve
Send a message via AIM to BillyGoats
Yeah they run about the same speed if geared correctly look at this from our robot.
http://www.valleytech.k12.ma.us/robo...ectronics2.JPG
There left and right drive side. Drills on one Chips(CIM's) on the other. There is a slight difference when you go full throatal but all you do is keep the Chips full and let down a little on the Drills. Works easy and have been driving it for almost 3 weeks now.
Last year we did the same thing and it also worked well.
FESTO Help ASAP!!!! Clark Gilbert Rumor Mill 19 29-04-2003 02:20
Q&A Discuss: FESTO Help ASAP!!!! CD47-Bot Extra Discussion 3 16-02-2003 10:55
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
** Urgent: CHICAGO Paging System archiver 2001 0 24-06-2002 02:49
Course Curriculum for A First Class, Please Respond ASAP archiver 2001 0 24-06-2002 01:33
