Go to Post Wow, my dad's sadistic nature is rubbing off on me. - Lil' Lavery [more]
Unread 17-02-2004, 20:17
Umm Errr...
Traction trouble
This year, our drive train works great, except one small problem: We are using the skyway wheels from the kit, but it is way to easy to burn out in them. They don't get enough traction. Does anybody know of any wheels of similar size that have much better traction from skyway or other sources? We have 2 wheel skid steering so too turning will not be a problem. We have room to double up the wheels or use wider ones. Any suggestions? DO the black wheels get more traction? What about modifying non-pnumatic tires? Please help!
1139 Alumni
Unread 17-02-2004, 20:39
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: Traction trouble
We are using pneumatic go-kart racing slicks again this year but upgrading to 12". If you are looking for traction these are superior. If you are looking to not cry when you put your robot on a scale find another source. They weigh like six pounds each. And we are using four in a four wheel drive skid steer setup. No one is pushing us off a six inch step...Unless we do it to ourselves. Lol.
Unread 17-02-2004, 21:49
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
If you are using skid-steer as in 2 wheels and 2 skids, your problem may be that you dont have enough weight on the drive wheels. If you can shift some weight over to them, you will get better traction.
Team 1257
Unread 17-02-2004, 22:00
Umm Errr...
I assure you most of our weight is over the drive wheels.
1139 Alumni
Unread 17-02-2004, 22:15
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
If you can go to a 14 inch Wheel, skyway has a tube and tire kit that fits on the 12 wheel hub, it is wider and has pretty aggressive tread. This will also make your bot faster, 12.5inch to 14 inch. They also were selling the whole thing filled and assembled. The part number for the whole tire and wheel is WHL1250 Sub 300-8 The part number for the tire only, you still have to get a inner tube, is Tire 2062 I don't have notes on the inner tube. Good luck BTW some of the pics in posted of this years bots have the 14 inch tires.
Unread 17-02-2004, 22:17
Dick Linn's Avatar
no team (Synergy)
What tire pressure are you using? Gearing? Be more specific and we'll see what we can advise.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 17-02-2004, 22:22
Umm Errr...
Tire pressure. We tried deflating the tires. Gearing? Don't remember of the top of my head. We have the Chips and Drill combined on each side of the bot. I want to say somehing around 30:1 from the drills and the chips are matched at free speed to the drills.
1139 Alumni
Unread 18-02-2004, 20:47
andy's Avatar
andy andy is offline
Alumni
FRC #1139 (Gear Grinders)
Team Role: Student
andy is a jewel in the roughandy is a jewel in the roughandy is a jewel in the rough
Send a message via AIM to andy
Lemme elaborate James,
We have roughly 130 ft/lbs of torque per wheel, we move at a top speed of about 8 ft/sec. We have plenty of power, but we cannot get the power to the ground, we are doing burnouts and skidding on carpet. We are looking into other wheel options, we are looking at things like gokart slicks and solid urathane skyways.
Thoughts?
-Andy
Unread 18-02-2004, 20:51
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
skyway sells a version of some of its pneumatic wheels where the air tube is replaced by a hard foam insert. they have excellent traction, but I'm not sure that you can get it with the big wheels (ours our only 6")
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 19-02-2004, 12:28
AKA: Nelson Green
Thoughts?
-Andy
My thoughts would be two front gokart slicks and then for the back have a wheel with lots of forwards traction but not much side to side traction so you can turn. We used 4 gokart slicks last year. See the picture. We ended up putting caster on cyclinders to drop down when we wanted to turn a lot. We were reseting breakers. So these would be great for the front but find a better way for them to slide in back with out giving up the traction forwards. Maybe fully inflating them would help some though.
Unread 19-02-2004, 22:56
andy's Avatar
Alumni
Team Role: Student
Hey all, thanks for the input!
We are using two drive wheels with two skids on the rear.
(we're using skids cuz we thought we wouldnt be able to skid stear-have had bad experiences in the past)
Today I came up with a new concept. Put another set of drive wheels just behind the others. That way we have the best of three worlds: we have great traction, turning ability (because the wheels are close together), and we can drive in straight lines easier. Also it is narrower then the gokart slicks so that we can still drive up the stairs and make it around the goal.
Try my poor ASCI drawings
where
() = wheel
v = skid
- = frame
*current side view*
()-------v
*proposed side wiew*
()-()----v
This option would be very easy to add to our robot and would add only about 10 pounds of weight and it just so happens we have weight to spare.
By the way, who is your supplier for the gokart slicks? I've had the hardest time finding them on the internet. Thanks!
Thoughts? Opinions?
Thanks
-Andy
Unread 19-02-2004, 23:37
AKA: Nelson Green
Its a local distributor but I am not sure where they get them from. It was all by accident last year too. We wanted knobby tires and after we ordered them we got the slicks back. But the worked great. I like your new idea a lot. We do have traction problems but we need the traction to get over the step. Good luck.
Anyone else having trouble keeping up with work? D. Gregory General Forum 36 28-03-2004 16:55
Materials for traction parteyboy10 Rules/Strategy 1 13-01-2003 21:15
traction questions AlbertW Rules/Strategy 2 05-01-2003 17:58
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
New Haven ball trouble Jeff Rodriguez Regional Competitions 1 04-04-2002 21:47
