Go to Post I can't believe I let build season distract me from the fact that iHop had unlimited pancakes for a few weeks. - IronicDeadBird [more]
Unread 15-02-2004, 13:19
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 1067's robot (almost done)
Unread 15-02-2004, 13:21
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Re: pic: 1067's robot (almost done)
Well, there she is.
Questions, just post em here.
First question answered today is: Why yes, those are marbles in the front wheels.
And a close up of our finish (only on that right leg as of now)
Again, questions/comments welcome. Yes, everything that is connected works, so far.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 15-02-2004, 15:46
occra 23.
AKA: ryo
None #1481
marbles are glass right??? and a 130lbs robot slamming into a diamond plate 6in wall at (i dunno how fast you guys are, but say) 6ft/sec. is that marble still intact?
and how did you get those marbles to stay in the hole? apoxy?
Unread 15-02-2004, 15:55
#1067 (SLUH)
Yes, they are glass. And yes, perhaps they are breakable, but we have driven this thing on concrete at 8'/second with no breaks.
We realize it might be a problem, thats why we didn't glue them in (we haven't had ny fall out, either) so we can replace them easily.
we also drop the marbles alot, on concrete, with no problems.
Come to think of it, I've never ever seen a marble break. A sphere is a pretty strong shape.
BUt we might break one or two during competition. Thats what spares are for.
Unread 15-02-2004, 16:02
occra 23.
AKA: ryo
None #1481
oh they break alright. in middle school, i once tried to beltsand a marble into a shape of a cube. the sander did grind quite a bit of the marble away before the marble literally exploded. yes. it was pretty scary. thankfully no teachers were watching. no harm done, but i learned my lesson. still don't know exactly WHY it exploded, but it did.
that doesn't prove if marbles will break on impact but if i were the judges, i might say that it is a hazard in the field because IF it breaks, it can be sharp.
i'd check with FIRST if i were you.
i'm also looking for a way to help us turn easier. i'm not sure zip ties are the best way either. if anyone thinks up an idea, please contact us or post it somewhere.thanks!
Unread 15-02-2004, 16:37
#1067 (SLUH)
ANother idea is to buy flooring epoxy (have you ever seen an epoxy floor -- I have one in my house, its good stuff) and cover the kit pneumatic wheels with it and let them harden. Then you have (basically) wheels with epoxy treads, plenty slick enough for you.
Unread 15-02-2004, 17:15
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
two questions- is it top heavy at all, and how long does it take you guys to get your arm up to the bar?
looks pretty slick- nice job
Unread 15-02-2004, 17:19
#1067 (SLUH)
The whole thing pictured weighs in at 90-110 lbs, somewhere in that range.
The CG is low enough that we can drive it around all crazy like and not flip (although I could make it do wheelies before we dropped the arm in).
if we get our wheels on another robot and keep driving we could go over. We can do the little stairs no problem, and if we can et up the 6 in step we have talked abour using the arm as a counterbalance to keep it from going over.
We can get that arm straight up in a few seconds. Maybe a bit longer to do the precision adjustments nescessary to get the hook on the bar.
Unread 17-02-2004, 21:41
#1067 (SLUH)
Ok, some updates (and a shameless bump, though I do hate double-posting)
We have a sprocket drilled out to fit our turret shaft. The big (3") hole visible in the motor plate is for a FP motor, and the sprocket will fit inside the robot on the big pole, and be driven by the FP motor. thus we can turn our arm around and around. More difficult to build, but it should be awesome to have the driver park the both and let the arm operator do his thing, without all the inefficiencies that happen in less-thatn-perectly trained teams.
Driving is becoming harder with the arm, but it is still much faster and handels much better than our 2003 robot. It requires experience, though. The dedicated freshman can tip it over while driving, although all of us were putting it through a stress test and he is the only one who almost made it flip. Inexperienced as he was, he reacted fast enough to save it. Maybe he has potential as a driver, but not this year. If it goes over without something else causing it, its our driver's fault. Hopefully we will get one smart enough to know whats what. Turning with the marbles is great, although we may look into non-glass replacements. Its gotta be something with balls, though, its just too funny of an idea. Back to the point of this paragraph: as of now the controls for the arm aren't finished, so the arm is unpowered when we drive. Therefore it has a tendency to flop around some, especially the rotating (turret) part of is which is not connected to a motor, so if the driver makes the wrong move, the arm freewheels around the robot. No major problems, but its something we are keeping an eye on.
The claw is marching steadily towards completetiong (especially because we still have 9 days till ship!) and I don't think there will be a problem with that, but then I did design it and I am building it, so I may not be that objective. Everything works so far.
I hope to get some more time with that hand-grinder soon and do that finish. Its ridiculously cool. I hung that one sample peice from the ceiling of our room with a few zip-ties. Its our substitute for art. Or maybe its our art. Maybe.
Well, theres the update. Hopefully more pics tommorow. Anyone know where I can host ~5meg divX files, I took some of them and would like to show them off.
pic: Team 147 our robot CD47-Bot Robot Showcase 3 04-02-2004 22:56
pic: 114 inventor robot CD47-Bot Robot Showcase 15 02-02-2004 19:52
pic: George the Faithful Robot Rodeo Annoucer CD47-Bot Extra Discussion 5 06-11-2003 13:27
pic: Team 639 Robot Before Ship CD47-Bot Robot Showcase 11 31-03-2003 21:35
XCats - robot pic on our website archiver 2001 0 24-06-2002 01:06
