Go to Post And your other point, "why a debate over a nonexistent rule?". Its summer, we're not building robots, and we're geeks. What else are we supposed to do? - EHaskins [more]
Unread 17-02-2004, 13:52
blindguyinanorg's Avatar
Happy Birthday! blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
Volume of tank + tube
we have our 2 tanks and about 3/4 of the tube on the 120psi side. i was wondering if anyone else who did the same thing knows aproxamatly how much the volume is or if it will easiy power the 1.5bore 8" piston in and out twice.
"No drugs, not even alcohol cause the fundementa ills of society. If we're looking for the sources of your troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, freed and love of power" - PJ O'Rourke
Unread 17-02-2004, 14:01
ngreen ngreen is online now
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: Volume of tank + tube
I would think so...But at what pressure? Does it need to keep a certain pressure and force like it is for lifting? I thought the tanks were like 16 cu. in. I not sure if that is together or by themselves. And 3/4 of the 20 feet of tubing??!!
Unread 17-02-2004, 15:59
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
By my calculations, you can get just one cycle in and out at 60psi. The next one will be at greatly reduced pressure.
The Clippard tanks are 16 cu in each. That piston should take at most 14.1 cu in for an extend, and slightly less for a retract. thus, after one cycle, the air in the volume tanks will be at 60 psi, thanks to one of those nitfy gas laws whose name I can't remember. P1*V1=P2*V2. And I'm ignoring the volume of the tubes, as it is relatively negligible at this scale.
If you want to get all those shifts out of the 2 tanks, turn your regulator down to 40-45 psi. That should get you exactly that many shifts out of your piston.
Unread 17-02-2004, 16:26
The equation is right, but you forgot the accumulators are at 120psi. I'm also not sure about your volume calculations. I thought the accumulators are 2" bore x 6" long, which gives 18.8 in^3. I could be wrong, but the answer won't be terribly different if they are 16 in^3
You use 14.1 in^3 (at 60 PSI) when you actuate the cylinder. The accumulators hold 37.6 in^3 (at 120 PSI). Since you are only using the air at 60 PSI, you effectively have 75.2 in^3 of air, and when you get down to 37.6 in^3, you will only have 60 PSI. Thus, you have 37.6 in^3 of air to work and can actuate the cylinder twice. If you can regulate the cylinder to 50 PSI, you could get 3 shots.
Unread 17-02-2004, 20:30
AKA: Nelson Green
It is 16 cu in for each tank..I read that in the manual kit of parts. As for acuation. The easiest answer is not to rely on equations and just test it.
Unread 17-02-2004, 21:47
Yes, I was going by what was said in the manual as well. And the 16 figure is on Clippard's website as well, so I can only assume it's closer to being correct. So I went with the 16 figure and didn't bother with a calculator. I just estimated it out. Yes, figuring that 32in^3 at 120 PSI is effectively 64in^3 at 60 PSI minus the 32 that must be left in the tanks. so 1 cycle of extend retract. or 2 shots by your counting method. I whipped out a calculator later and 45psi seemed about right for 4 shots.
Unread 17-02-2004, 22:21
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
Why not simply try it?
BTW, if you mean 3/4 of the tubing in the kit is on the 120 PSI side of your regulator, then you are clearly using the tubing as a storage device, and this is not allowed.
The rules state that only the tanks may be used as storage devices, and one of the Q & A answers stated that excess tubing was not allowed for compressed air storage.
Yes, we would like larger tanks as well...
-Mr. Van
Coach, 599
Unread 18-02-2004, 00:00
Matt Spencer
AKA: Sexy Beast
oh no why would they make that rule. last year we were aloud to do it.
sometimes i get the feeling that the guys at FIRST like to just make up rules.
i.e. the sound rule
Unread 18-02-2004, 00:32
AKA: Nelson Green
You can just leave lots of slack. If you have a cyclinder on an arm put an air tank up there and connect with loose tubing.
tank treads vs. threaded wheels lj8758 Technical Discussion 14 24-01-2003 00:30
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
pneumatics tank archiver 2000 2 23-06-2002 22:43
Filling the pneumatics tank archiver 2000 4 23-06-2002 22:43
tank or go-cart style steering? archiver 2001 17 23-06-2002 22:42
